Laser Mesh Exhaust Port Filler Panel C61073 For C6 Corvette
Platinum Supporting Vendor
This laser mesh accessory is constructed of premium 304 stainless that is perfectly laser cut into a precise diamond mesh pattern and then hand finished and specifically engineered to achieve the sparkle and glitter you expect. The diamond finish is not the common wire mesh found in other accessories of this type. This unique line of accessories will compliment your Corvette's sleek body lines and require no modifications. They are easy install and because they are stainless steel, will never tarnish, pit or lose their luster. Made proudly in the USA!
Application
2005 2006 2007 2008 2009 2010 2011 2012 2013 C6 Corvette (all models)
Application
