Data Card
Old Apr 16, 2023 | 09:32 PM
Jeff Turner's Avatar
Jeff Turner
6th Gear
Default Data Card
New Corvette owner here:
Could you please tell me where the white Data Cards can be located on the 2008 Corvette please?
Thank you.
Old Apr 16, 2023 | 09:40 PM
Patsgarage's Avatar
Patsgarage
There should be a sticker in the glovebox with all of the RPO codes your car was built with.
Old Apr 16, 2023 | 09:57 PM
Jeff Turner
6th Gear
I found that on the glove box door.
I was referring to the white Data Card that are presented on some of the C6 for Sale?
Looks like a laminated card??
Thank you.
Old Apr 16, 2023 | 10:27 PM
Patsgarage's Avatar
Patsgarage
Thank you.
I am not familiar with what you are talking about.
Old Apr 16, 2023 | 10:33 PM
Chukman's Avatar
Chukman
You might be referring to the Build sheet - that might not be the actual name for it. This is the build sheet that dictated how the car was to be built & outfitted from the factory. I ordered one a while back but at the moment don't recall where I got it or how much it cost. I'm sure someone will give you more specific info here before too long.
Old Apr 16, 2023 | 11:00 PM
jbc1995fb's Avatar
jbc1995fb
You can get it from the National Corvette Museum.
Build Sheets, Window Stickers (corvettestore.com)
Old Apr 16, 2023 | 11:12 PM
LCZ06's Avatar
LCZ06
Originally Posted by jbc1995fb;[url=tel:1606520421
1606520421[/url]]You can get it from the National Corvette Museum.
I had no idea you could still order one. Might have to do that sometime. I did pick up an original copy of the dealer brochure for the C6 Corvette with DVD off EBay.
Old Apr 17, 2023 | 03:33 PM
I M Tweety Bird's Avatar
I M Tweety Bird
If you join the museum as a member (which I highly recommend) you will get a discount on the window sticker & build sheet. Your membership helps support the museum & gives you lots of other privileges there in addition to their magazine.
Old Apr 18, 2023 | 08:18 PM
JABCAT's Avatar
JABCAT
I would check to see if the repo window sticker is accurate for your car. For whatever reason, the repo window stickers from NCM for the Carbon Edition Z06s are not accurate and inflate the price of the car. For example they list separately the CFZ pkg for $3,995 but it was included as part of the $15k Carbon Edition pkg. They also list the two paint colors as cost options ($300) but they were the only colors available & at no cost.
Maybe they're accurate for other trim levels, idk.
Old Apr 19, 2023 | 09:31 AM
I M Tweety Bird
Did you contact the NCM about the discrepancy in the window tag? They get these via the VIN # and are not supposed to be generic in nature.
Old Apr 19, 2023 | 03:28 PM
JABCAT's Avatar
JABCAT
I didn't as I have my original. But I've seen several Carbon Edition repo stickers and they are all the same with the options added separately and inflated MSRPs. There was one for sale on BaT a little while back and the owner was claiming it was originally $113k with the repo window sticker to prove it. With every available option (like mine has) the original MSRP was a tick over $100k.
You can see the discrepancies in these photos.
Old Apr 19, 2023 | 03:51 PM
I M Tweety Bird
My first question would be: If you are sure that they came from NCM and not from another source?
Old Apr 19, 2023 | 06:30 PM
JABCAT's Avatar
JABCAT
I'd have to search for it, but yes the owner ordered a replacement from NCM. I've seen more than one like this and the owners said they ordered from NCM. I didn't want to spend the $85/$100 for an incorrect sticker.
To Data Card
