Flashing temperature/AC/fan settings
I have a C-6 GS with 20K miles on it... I just got in the car started it and the indicator panel between the two temperature control ***** is flashing. The AC works, the fan works and I can change the temperature.... but the LED indicator area is flashing. I looked in the owners manual... nothing... I turned the car on and off... still flashes..... I drove it 3 days ago... all was good.... the only thing I have done different is put on my NOVA stretch bra..... the same way I always have.... what is going on?
I think I read somewhere that that indicates the outside temp sensor isn't working but could be completely wrong.
What did you mean you just got it started ? Did it have a dead battery ? Did you just charge up the battery, or put a new one in it ?
My 2013 GS Heater & A/C control module will do the same thing from time-to-time. I assume that eventually the LCD screen will go blank when the module fails. I have read several threads on the forum that the cause is improper cold solder joints with the electronic connections on the PCB. I posted a link below that explains the cold solder joint problem in detail.
https://versae.com/avoiding-the-cold...20over%20time.
New modules are no longer available, but rebuilt units can be purchased from several different vendors. OR if you are handy with electronics and capable with a soldering iron, you can rebuild your own module. Sample link below:
https://www.timmerschevyparts.com/oe...MTU4NTg4MTM%3D
Hope this helps...GD
Landru (04-20-2023)
Mine's been doing this for a while, now it's gotten to the point to where it will blow hot air from the driver side and cold air from the passenger, or get stuck on defrost/switch over to floor.
Was able to band-aid it for a while and reset it by pulling the fuse in the passenger floor board and re-setting it. Now that does not seem to help.
