Low speed stumble
Old Apr 21, 2023 | 09:52 PM
Prb1948's Avatar
Prb1948
Default Low speed stumble
My new to me has a low speed stumble at idle and into 1st gear. It doesn’t do it all the time. Today it was noticeable and after a pit stop for a burger it didn’t do it for the last coupe of miles. It’s a 06 with 30k miles. I bought it 5 months ago with 26,600 miles and dealer said plugs and map sensor was changed. I now have my doubts. I do not have a check engine light and have run techtron through it. I assume coil packs and wires are original. Any thoughts other than starting over
Old Apr 22, 2023 | 09:03 AM
ClothSeats's Avatar
ClothSeats
Sounds like the dealer was aware of the problem and tried to fix it with quick change of plugs and MAP sensor. When that didn't do it, they gave up before spending more money on it. The cause of your issue is probably something minor, but it just takes some time to do some diagnostics in order to find it. I think your best bet would be to find a good diagnostic shop in your area before you start spending money replacing parts that don't help.
Old Apr 22, 2023 | 10:53 AM
dr_gallup's Avatar
dr_gallup
My first step would be to look at all the hoses for cracks or loose connections. Second would be to clean the MAF sensor.
Old Apr 22, 2023 | 02:35 PM
BadAV's Avatar
BadAV
Clean the MAF sensor AND throttle body. Especially throttle body. Dirt/carbon buildup around the throttle butterfly edges many times leads to rough idle/low throttle stumbling. Also make sure the plug wires are fully seated on the coil packs and plugs; OEM wires seem prone to stubborn seating. It's pretty inexpensive to try these items.
To Low speed stumble
