Stripes
Old Apr 29, 2023 | 11:59 PM
vetteJPJ's Avatar
vetteJPJ
Default Stripes
Anyone had to remove racing stripes from their Vette? Mine need replacing really bad.
Old Apr 30, 2023 | 08:49 AM
MNcorvetteC6's Avatar
MNcorvetteC6
Removing vinyl stripes is a chore at best and a nightmare if worse. It can surely test your patience and your attention to detail. Solvents are pretty much out because of prolonged contact with the paint and potential paint damage. Use a hair dryer to slowly heat the stripe and soften the adhesive. Once the adhesive begins to release enough pull the vinyl back slowly. Pick up a soft plastic bondo spreader at the auto parts store to help ‘scrape’ between the vinyl and the paint if it pulls off nicely. If the stripes are brittle or cracked this will prove to be a long process. Also, be careful if you use a heat gun rather than a hair dryer because you can overheat the paint and cause real damage. I hope things go well and this proves to be just some weekend attention to maintaining and detailing your vette.
Old Apr 30, 2023 | 10:35 AM
I30's Avatar
I30
Veteran: Coast Guard
I had racing stripes that were brown in my seat. when I took a corner to fast.
Old Apr 30, 2023 | 10:53 AM
leebay's Avatar
leebay
A eraser wheel and a drill works well.
Old May 1, 2023 | 01:17 AM
vetteJPJ's Avatar
vetteJPJ
I've seen these on youtube. Some say that they damage the paint. Is there a certain brand you recommend?
Old May 1, 2023 | 01:20 AM
vetteJPJ's Avatar
vetteJPJ
You're a funny guy.......
Old May 1, 2023 | 07:10 AM
wayback's Avatar
wayback
Hair dryer to warm the stripes. Then start to pull the stripes back . Pull away from the stripes, keeping the adhesive facing the car. Pull with steady pressure as someone keeps warming the stripe at the contact spot. Don’t stop until stripe is off or a line of adhesive will be left on the paint.
Rubbing alcohol can be used to remove any remaining adhesive without harm to the paint.
Google has videos showing how to remove stripes the correct way.
Say it’s a stripe on the hood of the car, you would pull like your backing away from the car bumper, not pulling towards the windshield from the bumper.
Old May 1, 2023 | 08:48 PM
DrKrieger's Avatar
DrKrieger
When I removed the stripes from my Viper I used the hairdryer, and some lemon essential oil and the glue came off easily. Worked great!
Old May 1, 2023 | 09:02 PM
PMPerformance's Avatar
PMPerformance
they do not damage the paint. I’ve used one on mine.
To Stripes
