Transmission overfilled?!?
Old May 17, 2023 | 11:33 AM
tonmarchelli's Avatar
tonmarchelli
Default Transmission overfilled?!?
Working through some kinks on a new-to-me Z06. There are signs of a small leak from the weep hole at the transmission/torque tube. evidence of oil on the bottom of the transmission caked turned dark with dust, heard its called butt rot on a transaxle car. the car shifts perfectly, hasn't leaked any fluid on the floor....unless I jack up the rear. Then I will get a slow drip from the weep hole by the torque tube. I changed the exhaust recently and when the rear was jacked way up it dripped quite a bit. I figured I'd at least top it off for now while I figured out what was up. I leveled the car out on jack stands and opened the fil plug and transmission fluid poured out of it. Maybe 3 or 4 oz. Surprised me as I figured it would be low. I let it slow to a drip then put the plug back in. I ran the car for a bit to circulate the fluid, maybe 30 seconds. The prior owner had the torque tube rebuilt about 2000 miles ago. its a 2006 Z06, was told it has a TR6060 swap.
What could be going on here?
I plan on driving the car a bit and checking the fluid again. Only way to check the fluid is to take the fill plug off and top off correct? How can I check if its the TR6060 in this car?
Thanks all?
Old May 17, 2023 | 12:04 PM
Kevin Mason's Avatar
Kevin Mason
What's "butt rot"?
Old May 17, 2023 | 12:23 PM
tonmarchelli
Originally Posted by Kevin Mason
What's "butt rot"?
Term I’ve seen used for the dirty dusty oil that turns everything black from a leak.
Old May 18, 2023 | 03:24 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
Thanks all?
If the fluid flowed out of the fill plug with the vehicle level, then somehow the trans was overfilled. Clean everything & keep watch to see if there's still any leak.
To Transmission overfilled?!?
