Kitty Cats!!!
I need to replace one cat on the passenger side and should probably replace both. The one on the right blew out the material inside and I fished out as much as I could see in the tail pipe. Has anyone used the Magna flow cats which are around $575 each and claim to be exact fit replacements. Actually if anyone has replaced a cat which ones did you use and were you happy with the results? I have a 2010 GS 6sp. automatic.
