Battery cable.
Old Jun 9, 2023 | 04:26 PM
Maximus68's Avatar
Maximus68
Default Battery cable.
For the life of me, I cannot get this off. What am I missing?
Old Jun 9, 2023 | 04:35 PM
Klawp's Avatar
Klawp
Did you apply some elbow grease?
Old Jun 9, 2023 | 04:36 PM
ClothSeats's Avatar
ClothSeats
Loosen the nut until you can turn it with your fingers, then rock the cable connector clockwise and counterclockwise while lifting. It also helps to pry with a screwdriver at the side away from the cable while lifting on the cable end. Put some beef on it.
Old Jun 9, 2023 | 05:01 PM
FatsWaller's Avatar
FatsWaller
Looks like there’s a fair amount if corrosion between the post and clamp. I’d spray a bit of WD 40 on there and let it soak in for maybe 15 minutes. And as suggested, the nut must be loosened before you try to remove it. I have to say, though, that one thing this style of clamp does not do is hold on very tight. I had do use a socket large enough to just fit over the post, and then gently tap the clamp down before tightening the nut before I could get a solid joint. And even then, it was never a problem to rotate the clamp back and forth a bit after loosening the nut and then to pull the clamp up. No lever of any kind was ever needed.
Old Jun 9, 2023 | 05:36 PM
madsonp's Avatar
madsonp
I don't think I'd use WD-40, it's flammable and the cable arcing could cause it to catch fire.
Old Jun 9, 2023 | 06:47 PM
FatsWaller's Avatar
FatsWaller
I certainly wouldn’t spray it on something that was arcing, but WD40 seems to think it’s OK for battery posts
Old Jun 9, 2023 | 06:57 PM
B y r o n's Avatar
B y r o n
Once the bolt is totally loose it's only a matter of rocking and tilting the cable. It will come off.
Old Jun 9, 2023 | 07:43 PM
Maximus68's Avatar
Maximus68
Absolutely. But what is that clip?
Old Jun 9, 2023 | 07:45 PM
Maximus68's Avatar
Maximus68
I did that. But what is that clip looking overlap grip? Normally, I’d rip it off. But I thought I’d ask here first.
Old Jun 9, 2023 | 07:46 PM
Maximus68's Avatar
Maximus68
I got the nut completely off. Rocked it. Is something holding it down or on?
Old Jun 9, 2023 | 07:47 PM
Maximus68's Avatar
Maximus68
I tried rockin it. I’ll put the screwdriver under it now
Old Jun 9, 2023 | 08:00 PM
FatsWaller's Avatar
FatsWaller
Don’t rip off the clip. It’s used as an anchor to draw the clamp tighter. The conical nut when tightened against the slot causes the part that hooks over the clip to pull towards the stud that has the nut. The stud sticks up through the slot and is attached to the other side of the clamp.
Old Jun 9, 2023 | 09:59 PM
Lee Cromwell's Avatar
Lee Cromwell
I have one of these tools, they work great.
Old Jun 10, 2023 | 08:23 AM
Maximus68's Avatar
Maximus68
Thiank you. Will give it a shot. I just got the car. 2008 AO Z06 3LZ. In December actually. Looks like it’s a battery from 2019.
Old Jun 10, 2023 | 08:25 AM
Maximus68's Avatar
Maximus68
Thanx!!
Old Jun 20, 2023 | 02:31 PM
bignikmusic's Avatar
bignikmusic
Replace those shitty terminals with something like these. They clamp better, gold plated for less corrosion, and they have extra holes to make adding extra relays or stereo wires super easy.
Old Jun 21, 2023 | 11:30 AM
LCZ06's Avatar
LCZ06
Originally Posted by bignikmusic;[url=tel:1606755666
1606755666[/url]]Replace those shitty terminals with something like these. They clamp better, gold plated for less corrosion, and they have extra holes to make adding extra relays or stereo wires super easy.
How difficult is it to replace the stock ones?
To Battery cable.
Old Jun 21, 2023 | 12:55 PM
bignikmusic
Very easy. I snipped the old ones off. Degreased and straightened the wires. Put them in the new terminals and tightened down the set screws. Then install them on the battery.
I found them at autozone
Old Jun 25, 2023 | 05:45 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
You found these at Autozone ???…these OEM are junk…I have them tightened and they are still somewhat loose even with new conical nuts.
Old Jun 25, 2023 | 06:35 PM
bignikmusic
Yes they are working great for me. Can't believe gm used such cheap flimsy terminals.
Duralast Marine terminals
