Corsa extreme catback
Old Jun 16, 2023 | 05:25 AM
rtbehm's Avatar
rtbehm
Default Corsa extreme catback
Looking for buy for my 2005 C6 new/used catback exhaust. I found a used Corsa Extreme catback exhaust which was on a 2008 C6. Will or can this exhaust fit on my 2005 C6? Also, does Corsa Extreme stamp or mark their exhaust with a part number from the factory? Please advise and thank you, RT Behm
Old Jun 16, 2023 | 06:28 AM
ApexClone's Avatar
ApexClone
You'll need a 2008+ x-pipe/h-pipe for it to fit.
edit: 2009 was the year change actually. So 2008 mufflers will fit a 2005.
Old Jun 16, 2023 | 08:58 AM
rtbehm's Avatar
rtbehm
Thank you... Ill investigate. BTW, which one is preferred X/H pipe?
Old Jun 16, 2023 | 09:25 AM
old motorhead's Avatar
old motorhead
I've always heard that '05 - '08 mid pipes and mufflers would interchange. '09 - '13 are different compared to the early model years. I could be wrong......been wrong plenty of times before. You need to do a little more research before buying parts. I think that '08 Corsa setup will bolt right on.
Old Jun 16, 2023 | 09:31 AM
rtbehm's Avatar
rtbehm
Thank you for your comments
To Corsa extreme catback
