Rear hatch
Old Jun 23, 2023 | 04:37 AM
Triumph Jerry's Avatar
Triumph Jerry
Default Rear hatch
2009 C6 Manuel trans, arctic white.
Just noticed today that the rear hatch isn’t closing normally.
When pushing the hatch down, a motor would start and close the hatch, now I have to push down hard to get it to latch.
Not a big problem, but something isn’t right, anyone checked out the little motor that latches the hatch.
​​​​​​…..triumph jerry
Old Jun 23, 2023 | 09:29 AM
miss my Z06's Avatar
miss my Z06
Im having the same issue. Just started about a month ago. Like you said not a big issue but any input would help. 2009 C6 manual red. Thanks
Old Jun 23, 2023 | 09:55 AM
FatsWaller's Avatar
FatsWaller
Read through this thread and see if any of it helps. https://www.corvetteforum.com/forums...n-problem.html
If the hatch unlocks with the buttons or fob, there’s power to the latch, but you should check the rear electrical connector to make sure it’s fully engaged and also the 2 big blue connectors on the BCM just in case one is a bit loose.
Old Jun 23, 2023 | 10:06 AM
DrKrieger's Avatar
DrKrieger
Take a look at this:
Old Jun 23, 2023 | 10:46 AM
Triumph Jerry
Read the messages Fattwaller sent, …looks like it’s a $300 part fix.
To Rear hatch
