Window rattle
Old Jun 27, 2023 | 09:47 AM
Dttoys's Avatar
Dttoys
Default Window rattle
Good morning,
I'm hoping someone can lead me in the right direction. I have a 2011 Grand sport and I have a terrible window rattle in the pass.door. I can't find any info on window pads,or anything else related to what I would call a anti-rattle pad. I don't want to pull the door apart without knowing if there is a fix and a illustration would be wonderful.
Thanks in advance
Old Jun 27, 2023 | 10:26 AM
blownbayou's Avatar
blownbayou
I had a little rattle myself on my passenger side door also. When I pulled the panel to install new speakers, a little clip fell out. I could not find where it was supposed to be located (maybe a wire clip)...... No rattle ever since then. No ill effects either from not having the clip missing.
Old Jun 27, 2023 | 11:04 AM
FatsWaller's Avatar
FatsWaller
Maybe it’s not the window but the inner door panel that’s rattling. It’s held on by clips which sometimes break over time. If that’s the case you can get the fasteners from Amazon at way less than from GM. There’s two parts to the fasteners
Amazon Amazon
Amazon Amazon
Old Jun 27, 2023 | 11:20 AM
ClothSeats's Avatar
ClothSeats
Maybe the window just needs to be indexed. It's worth a try anyway.
Old Jun 27, 2023 | 12:53 PM
BrandonM7's Avatar
BrandonM7
https://www.amazon.com/Panel-Clips-C...dv_rp_0_1_ec_i
https://www.amazon.com/gp/aw/d/B00BJ...b_b_asin_title
Thank you for that. I've been too dumb to find these on my own and I need some.
Old Jun 27, 2023 | 01:10 PM
Dttoys's Avatar
Dttoys
Thanks for every one responding
It was one of the window regulator hold down nuts that came loose
Thanks again
Old Jun 27, 2023 | 04:59 PM
TCW's Avatar
TCW
St. Jude Donor '06-13,'16-'17, '19
Thanks again
Thanks to you for posting what fixed your problem!!
Tom
To Window rattle
