NOT Synchroed
Old Jul 7, 2023 | 01:39 PM
I M Tweety Bird's Avatar
I M Tweety Bird
Default NOT Synchroed
I think I am losing my 2nd gear synchro. In a medium pull in first to shift into 2nd I get some gear grind. I just finished sinking over 5K into the car last month and now I may have to get the tranny fixed too. Anyone had their trans rebuilt or had the synchros replaced? What kind of cost am I looking at?
06 C6 M6 Base Vert.
Old Jul 7, 2023 | 01:44 PM
DrKrieger's Avatar
DrKrieger
The prices are all over the place. If you pull the transmission yourself you will save an incredible amount of money.
Old Jul 7, 2023 | 01:47 PM
PMPerformance's Avatar
PMPerformance
Syncros will grind at any rpm and load.
id first make sure it’s actually a synchro first. Does double clutching fix the grind?
does it grind at all loads and rpm?
does it grind or scratch?
Old Jul 7, 2023 | 10:02 PM
Dano523's Avatar
Dano523
My guess, is sling shot'g the shifts, before the synchro clutch disc has time to speed match the gears, for a clean engagement.
So other parts may be fine, and the only problem is the friction disc (middle right), needs to be replaced since it worn out.
My guess, both the friction rings, and possible the engagement gear teeth tips are both worn for second gear, so semi into a trans rebuild in the ends.
To NOT Synchroed
