Bluetooth problem C6 GS
Old Jul 19, 2023 | 12:15 AM
Marine Tech's Avatar
Marine Tech
8th Gear
Default Bluetooth problem C6 GS
My 2010 GS has Nav, CD, DVD and XM and RDS. I am having a problem with the Bluetooth The car is not hearing me speak to it, so I cant use any BT options. Any Ideas?
Old Jul 19, 2023 | 08:14 AM
Geoff13IOM6GS's Avatar
Geoff13IOM6GS
bluetooth is only for phone operations - for this reason, and many more, most people choose to upgrade the head unit so they can have all the modern amenities. May not be the answer you like but you'll be happier in the end.
Old Jul 19, 2023 | 11:58 AM
Rick369's Avatar
Rick369
Delete the Bluetooth on your phone for the Corvette. Delete the Bluetooth for your Corvette in the cars memory. Start over and sync your phone to your Corvette’s Bluetooth.
Old Jul 19, 2023 | 01:06 PM
09LS3's Avatar
09LS3
Are you sure the microphone in the A pillar is working / plugged in ?
Old Jul 19, 2023 | 01:57 PM
FatsWaller's Avatar
FatsWaller
Do you get any response from the system if you press and hold the phone button on the steering wheel for 2 seconds?
Also, according to the last post in this thread, pulling the OnStar fuse disables Bluetooth. You might want to check that to see if it’s been pulled. https://www.corvetteforum.com/forums...r-removal.html
Old Jul 19, 2023 | 03:22 PM
MissileDoc's Avatar
MissileDoc
Concur, try this.
Old Jul 24, 2023 | 09:49 PM
sirdano's Avatar
sirdano
also make sure volume is up for bluetooth on phone. There has been times when mine got to no volume
To Bluetooth problem C6 GS
