Tire size question
Old Jul 23, 2023 | 11:10 AM
ggourley's Avatar
ggourley
Default Tire size question
I’ve read a lot of the previous questions/answers for tires, a bit confusing and sometimes conflicting. I only daily drive, no tracking, and have standard C6 rims. I want to upsize to 305s on the rear, and probably 255s on the front. For the 305s, is a 305/35/19 better than the 305/30/19 in terms of fit and height for the standard 10” rim? Thanks!
Old Jul 23, 2023 | 11:37 AM
DrKrieger's Avatar
DrKrieger
I run 305/35/ZR 19's on the rear.
305 is the width in millimeters. 30 or 35 is the aspect ratio (wall height) - 30% or 35% of the tire width. ZR is the speed rating. 19 is the rim diameter in inches.
Therefore...
305/30ZR/19 has a wall height of 3.6" (92mm)
305/35ZR/19 has a wall height of 4.2" (107mm)
This affects the overall diameter (& circumference) of the tire - your diameter and obviously circumference have grown (you can do the math from the different wall heights above). The 35 in opposition to the 30 will give a much better ride due to the increased wall height. Hope this helps.
Old Jul 23, 2023 | 11:43 AM
ggourley's Avatar
ggourley
Default Tire
Thanks! I’ve read a lot about the 305/30 being a bit wide for the 10” rim and squirming a bit when cornering, although for daily street driving not sure that’s a problem. Also tire diameter seems to possibly mess with traction control. Just a lot of variables. I’m looking at Nittos or Khumo tires btw.
Old Jul 23, 2023 | 03:38 PM
SimCar's Avatar
SimCar
NCM Lifetime Member
NCCC Lifetime Member
305/30-19 in rear and 265/30-18 in front will work. Works with FalkenAZENIS RT660. This is a smaller diameter than stock and the car will sit lower.
Old Jul 23, 2023 | 05:56 PM
ggourley's Avatar
ggourley
Default Thanks
Thanks for that info!
Old Jul 23, 2023 | 08:32 PM
old motorhead's Avatar
old motorhead
I'm running Michelin PS4's in 295/35 19 rears and 255/40 18 fronts. You can go 305/35 19's with the same fronts and not get the nannies to go crazy on you.
Old Jul 24, 2023 | 08:45 AM
C6ToGo's Avatar
C6ToGo
Tire Rack spec page was my go to site for looking up diameter and width for any size tire.
Not the size you are asking about, but I found a good price on rear 275-40-19s and the sizing seemed acceptable. But they rubbed in the fender well whenever I went through a good sized dip in the road.
Old Jul 24, 2023 | 09:09 AM
sramzzz's Avatar
sramzzz
You can go to this site to see the effects of different setups.
https://www.willtheyfit.com
To Tire size question
