Harmonic Balancer
Old Aug 30, 2023 | 06:20 PM
HBsurfer's Avatar
HBsurfer
The best way to see if they know what they are doing is to ask them how they torque the new bolt. If it is a new GM bolt, torque is 38# plus 140 degrees of rotation (double check those numbers but you get the idea). If he says 200#/ft or some other single number, he is guessing. Dealerships will use a new GM bolt.
Old Sep 1, 2023 | 10:01 PM
wood78221's Avatar
wood78221
Originally Posted by DEFCON5
Finally got my harmonic balancer installed by a local mechanic. He charged me $370 labor. I supplied a Summit Racing balancer, new bolt and crank seal. Around $650 total. If you're in North Central Ohio he might be worth checking out.
Good move. I just had one installed last week on mine also. Summit is a good choice.
