Right Rims
The glitch to this, is you need Base off sets in the rims, not the zr1 Wide body rim off sets, and back to finding rims with the rim spokes ID shallow enough in base off set rims to clear the calipers outer faces as well. There is the spacer option to push the rim spokes off the hub surfaces to maybe gain the needed clearances that way, but the glitch is push the rims too far off the hubs to end up with the outside of the tires proud of the fender, and first time tire crashes in to the fender lips via bump, it going to destroy the fenders.
Then we get back to brakes only as good as the tires on the car, so unless your going to run super cups or a tire with more grip, wider then normal stock tires to push the tires more towards the center line of the car to run the wider tires, really wasting your time by going with the carbon rotors in the first place. And that is once you do manage to get the rotors up to temp to grab in the first place.
With luck, someone has already pulled this off without needed spacer for at least the stock Base tire widths, but may be harder to find the needed rims for the brakes, while at the same time, able to take the wider tires while pushing them more to center line, so they are not protruding past the fender lips/ have the needed increase tire grip to justify the brake system on the base car in the first place.
https://www.google.com/search?q=C6+z...t=gws-wiz-serp
Yes on the larger size rim to push the barrels out farther, and your going to running lower Profile tires on them to keep the Tire ODs around the same size to fit inside the fender wells.
Yes on wider rims so you can run wider tires for the needed grip to justify having the brakes on the car in the first place, but off set needs to push the rims more to the inside line of the base narrow body car, not to the outside like the wide body rims do for the Zr1 and z06. Then you get into shallowness of spokes, so the front of the calipers don't rub on inside of spokes.
And to rub some more dirt in the wound, the OEM C6 Zr1 Brembo calipers, are no better than say the stock Z06 calipers from PBR (other than working with larger rotors). Hence both where severally value engineered by GM to get the price way,way, down on them for an oem part, and don't hold a candle to true race calipers.
If you just want a certain color caliper, there are plenty of options that 1. Are much, much cheaper & 2. Fit your vehicle. The ZR1 calipers aren't the right play.
