TPMS programming question.
Old Oct 24, 2023 | 10:30 PM
540 vette's Avatar
540 vette
Default TPMS programming question.
Just got new wheels, tires and TPMS for my 2005. I'm not ready to put the new stuff on the car but can I program the TPMS for the car. Put the new wheel and tire in the position they will be in and program them. And of course mark which tire goes where.
Old Oct 25, 2023 | 05:44 AM
jamieo's Avatar
jamieo
Yes.
Old Oct 25, 2023 | 06:07 AM
540 vette's Avatar
540 vette
Originally Posted by jamieo
Yes.
Will it read pressure or 0.
Old Oct 25, 2023 | 08:15 AM
FatsWaller's Avatar
FatsWaller
You don’t even need to put the sensors in the rims. Leave the sensor in its package and put on the ground 6” or so from the tire. Put the tool up against the package aimed at the sensor. The new sensor should report 0 since it’s not in a pressurized wheel. Don’t forget to label the package with the wheel position so the sensor ends up in the correct position, but you could always reprogram them if they don’t.
Old Oct 25, 2023 | 10:34 AM
FatsWaller's Avatar
FatsWaller
Having read your question again, you can only have 4 sensors programmed at a time. The sensors which are in your existing wheels would be deleted from memory. So if you intend to drive the car after programming the new sensors but don’t install them, the pressure will report as ‘XX’ for each wheel assuming you are out of range of the new sensors, and 0 if they are close to or in the car. Not an ideal situation. The nannies might limit what you can do.
Old Oct 25, 2023 | 11:15 AM
HK770's Avatar
HK770
Not seeing the need to pre program the TMPS With reading of 0 or xxx is not an advantage. And with it taking 5 minutes to program them in first place. Seems ill advised to me but your advantage may vary!
Old Oct 25, 2023 | 12:46 PM
FatsWaller's Avatar
FatsWaller
The advantage to preprogramming the sensors before they’re installed is that you avoid the cost of having to remove them and replace them if it turns out that they are incompatible with your car. Seems to happen often enough from various threads on this forum. I agree though that driving around with the sensors not programmed is not a great idea.
Old Oct 29, 2023 | 11:11 AM
MacB's Avatar
MacB
You are over thinking. Just get the inexpensive programmer from Amazon, less than 10 bucks, and program the new sensors and tires after they are installed on the car. Piece of cake.
Old Oct 29, 2023 | 12:00 PM
FatsWaller's Avatar
FatsWaller
You need to do some thinking. If the sensors are incompatible, and this happens, it’s going to cost you if you supplied the sensors and the tire has to be dismounted to insert the correct sensors. If you’ve got the $10 tool, use it before you install the sensors to make sure.
Old Oct 29, 2023 | 12:02 PM
Turbo6TA's Avatar
Turbo6TA
2021 C6 of the Year Finalist - Modified
And after you buy the inexpensive Chinese programmer, follow this 'easy as pie' procedure:
To TPMS programming question.
