Goodbye old paint
My maintenance costs were pretty high during my ownership of the C6. Just to name a few items I had to replace the a/c compressor, the power steering pump twice, the water pump twice, the crankshaft damper twice, shocks once, the clutch due to an oil leak, the torque tube assembly, radiator, starter motor five times, the brake mater cylinder and vacuum booster and many more repairs. Some things I was able to do myself, but I don't have a lift so anything under the car had to go to a shop. There were 31 engine oil changes, nine differential oil changes, three transmission oil changes, six sets of tires, several brake fluid flushes, several coolant changes and a lot more, but the car never left me stranded and it was always a joy to drive.
2008 Corvette Maintenance Record
Delivered November 18, 2007 5 miles at delivery.
Ed Morse Chevrolet. (Dealership sold to Schumacher)
Oil and Filter Change Mobil One 5W-30W Mileage Date
1. Ed Morse Chevrolet 2,794 03/21/2008
2. Maroone Chevrolet 9,463 07/23/2008
3. Maroone Chevrolet 13,610 01/09/2009
4. Maroone Chevrolet 16,967 05/08/2009
5. Maroone Chevrolet 19,947 10/05/2009
6. Jack Tucker 25,091 06/13/2010
7. Jack Tucker 31,674 01/08/2011
8. Jack Tucker 37,049 09/13/2011
9 Maroone Chevrolet 37,074 09/14/2011
10. Maroone Chevrolet 41,849 04/12/2012
11. Jack Tucker 47,276 02/01/2013
12. Jack Tucker 54,383 01/15/2014
13. Jack Tucker 59,389 08/01/2014
14. Jack Tucker 68,425 09/08/2014
15. Jack Tucker 75,119 02/10/2015
16. Jack Tucker 81,542 07/09/2015
17. Jack Tucker 88,536 10/19/2015
18. Jack Tucker 95,510 02/08/2016
19. Jack Tucker 101,810 05/10/2016
20. Jack Tucker 108,794 08/07/2016
21. Jack Tucker 115,925 03/30/2016
22. Jack Tucker 122,283 11/13/2017
23. Jack Tucker 129,482 07/31/2018
24. Jack Tucker 135,970 05/04/2019
25. Jack Tucker 143,687 11/29/2019
26. ProTek 144,656 01/28/2020
27. Jack Tucker 151,670 01/30/2021
28. ProTek 154,995 06/16/2021
29. Jack Tucker 163,722 04/28/2022
30. Jack Tucker 169,737 09/30/2022
31. Jack Tucker 176,776 05/03/2023
Diff Oil Change
1. Schumacher Chevrolet 16,486 03/01/2009
2. Jack Tucker GM Dif oil 37,049 09/13/2011
3. Jack Tucker GM Dif oil 50,863 08/30/2013
4. Jack Tucker GM Dif oil 82,284 07/27/2015
5. Jack Tucker Royal Purple 101,853 05/12/2016
6. Jack Tucker GM Dif oil 113,164 01/01/2017
7. Jack Tucker GM Dif oil 133,802 02/15/2019
8. Jack Tucker GM Dif oil 148,954 09/10/2020
9. Jack Tucker GM Dif oil 166,737 07/23/2022
Transmission oil change
1. Jack Tucker 37,049 09/13/2011
2. Jack Tucker 88,808 10/27/2015
3. Jack Tucker Castrol 133,802 02/15/2015
Engine Air Filter
Jack Tucker AC Delco (GM Partshouse) 44,064 09/05/2012
Jack Tucker Purolator (Parts Geek) 79,027 05/14/2015
Jack Tucker Purolator (Pep Boys) 115,925 03/30/2017
Jack Tucker Purolator (Pep Boys) 140,432 10/29/2019
Throttle Body/Air Mass Sensor Cleaning
Jack Tucker 140,432 10/29/2019
Jack Tucker 159,308 03/15/2022
Jack Tucker 166,118 07/08/2022
Brake Fluid Flush
1. Maroone 41,849 04/12/2012
2. Jack Tucker/Barry Hunning 120,419 09/19/2017
3. Jack Tucker/Prestone DOT 3 171,057 11/02/2022
4. Jack Tucker/Prestone DOT 3 175,204 03/26/2023
Power Steering Fluid Flush
1. Partial flush through reservoir 74,121 01/17/2015
2. Flush at time of pump replacement 75,472 02/20/2015
3. Partial flush through reservoir 151,150 12/10/2020
Coolant Change
Jack Tucker 47,897 02/21/2013
Road and Race 74,472 02/20/2015
ProTek 146,856 05/04/2020
ProTek 155,902 08/24/2021
Jack Tucker Prestone 159,308 03/05/2022
Jack Tucker Prestone 173,508 01/23/2022
Cabin Air Filter
1. Purolater 16,486 03/01/2009
2. Purolater 31,674 01/08/2011
3. Purolater 44,064 09/05/2012
4. Purolater 53,970 12/31/2013
5. Purolater 78,030 04/22/2015
6. ATP 102,344 05/23/2016
7. Purolater 112,285 12/10/2016
8. Purolater 122,383 11/15/1017
9. Champion 138,538 07/09/2019
10. Epaula 151,758 02/03/2021
11. AC Delco 164,149 05/07/2022
12. Purolater 177,232 05/18/2023
Wiper Blades
40,040 12/30/2011
54,383 01/16/2014
86,400 09/04/2015
124,114 12/02/2017
144,192 12/12/2019
Clutch Fluid Change
1. Jack Tucker Prestone DOT 4 79,027 05/14/2015
2. Jack Tucker Prestone DOT 4 88,536 10/19/2015
3. Jack Tucker Prestone DOT 4 95,510 02/08/2016
4. Jack Tucker Prestone DOT 4 101,810 05/11/2016
5. Jack Tucker Prestone DOT 4 108,794 08/07/2016
6. Jack Tucker Prestone DOT 4 115,925 03/30/2017
7. Jack Tucker Prestone DOT 4 122,283 11/13/2017
8. Jack Tucker Valvoline DOT 3/4 129,482 07/31/2018
9. Jack Tucker Prestone DOT 4 136,053 04/04/2019
10. Jack Tucker Prestone DOT 4 143,739 12/02/2019
11. Jack Tucker Prestone DOT 4 151,670 01/30/2021
12. Jack Tucker Prestone DOT 4 156,195 09/22/2021
13. Jack Tucker Prestone DOT 4 163,722 04/28/2022
14. Jack Tucker Prestone DOT 4 174,310 02/15/2023
15. Jack Tucker Prestone DOT 4 176,776 05/03/2023
Tires
Michelin RFT-Tire Rack-Installed by Maroone 32,996 03/15/2011
Right front tire replaced due to curb damage 34,123 04/22/2011
Bridgestone RFT-Tire Rack-installed at Autonation 77,760 04/15/2015
Michelin RFT-Tire Rack-installed at Autonation 121,792 10/27/2017
LR Tire repair Autonation 127,000 03/06/2018
Michelin RFT-Tire Rack/installed at Tire Choice 148,743 08/28/2020
Michelin RR RFT-Tire Rack/installed at Tire Choice due to damage. 152,151 03/03/2021
Michelin RFT-Tire Rack/installed at Tire Choice 175,358 03/30/2023
Alignment Mileage Date
1. Maroone Chevrolet 13,610 01/09/2009
2. Maroone Chevrolet 21,914 01/28/2010
3. Maroone Chevrolet 32,996 03/15/2011
4. Maroone Chevrolet 34,201 04/26/2011
5. Autonation Chevrolet 77,760 04/15/2015
6. Autonation Chevrolet 121,792 10/27/2017
7. Tire Choice 148,755 08/31/2020
9. Protek 155,902 08/25/2021
10. TireChoice 175,358 03/30/2023
Brakes
Brake Motive Drilled & Slotted Rotors (4) 56,962 05/09/2014
Brake Motive Ceramic Pads (4 sets) 56,962 05/09/2014
Fluid flush Road and Race 75,472 02/20/2015
Brake Motive Drilled Rotors (4) 120,371 08/29/2017
New Bendix pads all four wheels 120,371 08/29/2017
Speed Bleeders all four wheels 120,371 08/29/2017
Convertible Top Care
1. Coated top with Aero 303 47,050 01/15/2013
2. Coated top with Aero 303 53,357 12/14/2013
3. Coated top with Aero 303 59,384 08/01/2014
4. Coated top with Aero 303 76,720 03/17/2015
5. Coated top with Areo 303 83,067 08/10/2015
6. Coated top with Areo 303 83,067 08/10/2015
7. Coated top with Aero 303 92,650 12/08/2015
8. Coated top with Aero 303 101,810 05/11/2016
9. Coated top with Aero 303 111,554 11/11/2016
10. Coated top with Aero 303 120,240 08/22/2017
11. Coated top with Aero 303 134,426 02/23/2019
11. Coated top with Aero 303 144,215 12/14/2019
12. Coated top with Aero 303 153,062 03/20/2021
13. Coated top with Aero 303 166,787 07/20/2022
Warranty & Repair Mileage Date
* Maroone Chevrolet Squeak coming from the rear of the car; determined to be an improperly installed muffler hanger.
Problem solved. 1,458 01/09/2009
* Maroone Chevrolet Complained of top wear (smooth areas).
Advised normal wear. 13,610 01/09/2010
* Schumacher Chevrolet. Complained chimes
occur for no reason.P roblem not solved. Mark in
paint behind the headrest due to elastic in top.
Problem not solved .
(Mark no longer visible 03/27/2013)
Unable to open the trunk with remote, interior and exterior buttons.
Problem not solved. 16,486 03/01/2009
* Schumacher Chevrolet Differential TSO
completed, drain and refill differential. 16,486 03/01/2009
* Schumacher Chevrolet Bearing noise
from left rear. Problem not solved. 16,486 03/01/2009
7. Schumacher Chevrolet 16,730 03/13/2009
Tonneau cover latch replaced.
8. Maroone Chevrolet 19,947 10/05/2009
Complained of bearing noise from left rear. Problem not solved.
9. Maroone Chevrolet 20,152 10/30/2009
12 volt battery replaced, battery compartment cleaned.
10. Maroone Chevrolet 29,639 10/18/2010
Airbag Readiness Light came on two occasions, was advised that service did note the trouble codes on the computer, but unable to determine why the codes were observed.
11. Maroone
Airbag Readiness Light came on while passenger occupied right seat. Dealer handled under warranty and put dielectric grease on the passenger seat airbag connector and replaced the sensor in the driver seat-belt reel.
12. Tire Rack 32,996 03/15/2011
Replaced all four tires with Michelin ZP AS tires
13. Install and balance tires. Maroone 32,996 03/15/2011
14. Replaced right front tire due to curb damage 34,123 04/22/2011
15. FOB battery replacement, both FOBs 07/20/2011
16. Replaced oil pan gasket at Maroone Chevrolet 37,074 09/14/2011
18. Repaired right rear tire due to nail. 12/12/2011
New battery Optima 35(NAPA) 38,876 12/20/2011
Replaced both wiper blades. 40,050 12/30/2011
Defective oil filter replaced by dealer (Maroone) 40,073 01/09/2012
Maroone Chevrolet replaced heater inlet/outlet
hose due to acid leak from Delco battery 40,960 02/20/2012
Replaced air dam due to road wear Mid-America Parts
Maroone Chevrolet 4 forged polished aluminum
rims replaced original rims, tires mounted and
balanced. Purchased wheels from Housed
of Wheels 43,378 08/02/2012
Maroone Chevrolet Right rear tire repaired due to nail 43,378 08/02/2012
Central Auto Trim Replaced the driver’s
seat foam placed under seat and
reinforced outside bolster on seat . 43,984 08/30/2012
Jack Tucker cleaned throttle body 44,094 09/05/2012
Coated Convertible top with Aero 303 47,050 01/15/2013
Replaced front air dam due to wear. 48,895 03/27/2013
Mid America Parts
Coated convertible top with Aero 303 53,357 12/14/2013
All four rotors and pads replaced due to 56,962 05/09/2014
warped OEM rotors.
* Coated Convertible Top with Aero 303 59,384 08/01/2014
* Replaced fob batteries 72,250 12/04/2014
* Replaced right fender extension due to curb
damage 72,250 12/04/2014
* Replaced the two rear sway bar end links. 75,119 02/10/2015
* Replaced the power steering pump with pump 75,472 02/20/2015
from NAPA with Lifetime Warranty
Work done at Road and Race, Riviera Beach
work included:
> Flush power steering system
> Replace power steering reservoir
> Replace AC Belt and Accessory belt
> Replace the accessory belt drive idler pulley.
> Replace brake fluid
> Replace coolant
* Replaced the two front sway bar end links 76,421 03/12/2015
* Coated convertible top with Aero 303 76,720 03/17/2015
* Replaced the front spoiler 76,734 03/19/2015
* Replaced all four shock absorbers with
Bilstein Shocks 77,533 04/10/2015
* Replace hood supports (2) (Monroe-Pep Boys) 78,030 04/22/2015
* Cleaned throttle body and air mass sensor 78,030 04/22/2015
* Replaced the trunk supports
(Sachs-Stabilus Pep Boys) 78,808 05/07/2015
* Recall 9100986 UBEC Jumper Harness 79,645 05/26/2015
* New Optima Battery (NAPA) 81,019 06/18/2015
* New Starter motor (Autonation) 81,019 06/18/2015
* Replaced the harmonic balancer (Autonation) 82,475 07/30/2015
* Engine squeak returned. Car returned to Autonation
Car repaired no cost. Tech claimed the power steering
pump pulley was misaligned. Noted no belt wear and
the squeak did not appear for 7,000 miles of use. Also
noted why did tech not note the misaligned pulley when
installing the harmonic balancer. 82,649 08/02/2015
* Coated convertible top with Aero 303 83,067 08/10/2015
* Wiper blades (NAPA) 86,237 08/29/2015
* Replaced two F Straps GM Part 89024073 90,445 11/19/2015
(Parts keep the convertible top from hitting
the tonneau cover.)
* Coated the convertible top with Aero 303 92,650 12/08/2015
* Replaced the left front inner fender liner and the three
piece front air dam. 93,716 12/23/2015
* Removed and replaced spark plugs (AC Delco 41-110
Pep Boys) and spark plug wires (AC Delco 89018058
Cultrag Performance Parts) 96,094 01/15/2016
* Removed and replaced the left tonneau cover hinge at
AutoNation Chevrolet Greenacres. Also previously
replaced the hydraulic pump assembly with a used unit
from a 2008. 97,327 03/14/2016
* Removed and replaced the left tounnoe cover hinge
Autonation 97,327 03/14/2016
* Replaced one body screw to the lower left quarter-panel
that secured the left rear brake duct assembly.
Part purchased from AutoNation Greenacres. 100,750 04/18/2016
* Replaced the left front shock upper rubber grommets
due to damage caused by a pothole in Orlando. Used
parts originally received with Bilstein shocks. 100,750 04/18/2016
* Replaced the two F straps under warranty. 101,350 04/29/2016
* Replaced the AC compressor, valve, freon and lubricant
at AutoNation Chevrolet. 101,535 05/04/2016
* Repaired left rear tire due to puncture at Autonation
Greenacres 107,101 06/20/2016
* Reset tire pressure monitors due to inability at the time
of the tire repair, Autonation, Greenacres. 107,484 06/27/2016
* Repaired left rear tire at Tire Choice. Two nails
found by the store, one additional found not through
the tire. 108,710 08/03/2016
* Removed and replaced left door lock mechanism
(Part # 88965678) from Cultrag Performance
LLC.) 109,600 09/01/2016
* Removed and replaced all four sway bar end links.
(PEP Boys) 110,480 09/22/2016
* Removed and replaced all five light bulbs from the
right side Driver Information Center switch unit with
bulbs obtained from Radio Shack. 115,925 03/30/2017
* Cleaned the air mass sensor and the throttle body. 115,925 03/30/2017
* Replaced the mirror cover on the driver side sun
visor. (Obtained on Ebay) 115,956 04/03/2017
* Removed and replaced the driver’s side seat cushion
(Auto Nation) 115,956 04/03/2017
* Removed and replaced the left sill plate
due to breaking when working on the driver's
seat cushion replacement (Auto Nation). 116,960 04/09/2017
* Removed and replaced the clutch master cylinder
at Auto Nation Chevrolet under TSA 118,592 07/13/2017
* Added ½ quart of oil 119,494 08/04/2017
* Torqued the rear axle nuts to 118 Ft Lbs with
33 MM socket purchased at NAPA. Found both
nuts to be loose. 120,192 08/17/2017
* Replaced all four rotors and brake pads, installed
speed bleeders on all four calipers. 120,371 08/29/2017
* Replaced Optima battery under warranty, NAPA 120,374 09/13/2017
* Installed new Steel covered flexible brake lines
from Summit Racing with Barry Hunning. 120,410 09/18/2017
* New Master cylinder from NAPA installed by
Barry Hunning. 120,412 09/19/2017
* Replaced missing front left top nut on sway
bar end link (Ace Hardware). 120,412 09/20/2017
* Removed and replaced 4 tire sensors purchased
through Amazon from Cultrag, installed by
Autonation at time of tire install. 121,792 10/27/2017
* Tightened all the swaybar end link attachment nuts,
found two nuts loose. No more suspension rattles.121,800 10/31/2017
* Adjusted right rear brake line with Barry Hunning
due to line touching caliper duct. 122,020 11/03/2017
* Removed and replaced the left and right
front air dams, the center section was retained
due to minimal wear. 122,069 11/03/2017
* Removed the left and right air dams due to road damage
incurred at the Stuart Airshow. 122,220 11/05/2017
* Starter replaced under warranty due to previously
installing a rebuilt GM starter which provides a
lifetime warranty on the parts only. Charged me labor
at the first replacement rate of $115.00 per hour. 122,278 11/13/2017
* F Strap replacement. 124,155 12/06/2017
* Replaced both FOB batteries (CR2032) 127,136 03/14/2018
* Removed and replaced left tank fuel pump
Pump supplied by Cultrag, labor
Corey Corvette Repair 133,500 01/17/2019
* Remove and replace sill plates (Corvette Mods) 134,426 02/23/2019
* Removed and replacced left rear TPMS (NAPA)
by Corey at Proteck. 134,858 03,15/2019
* Removed and replaced hood struts. (Amazon) 134,870 03/16/2019
* Removed and replaced trunk struts. (Amazon) 134,870 03/20/2019
* Replaced light bulb in the right switch pod at the
Reset button. Also repaired the Trip button. 135,242 04/05/2019
* Torqued right rear axel nut 118 Lbs. 138,605 08/11/2019
* Removed and replaced starter motor with
Barry Hunning/NAPA Part 139,599 09/09/2019
* Remove and replace power steering pump.
Pump replaced under warranty through NAPA.
Installed by Barry Hunning. 143,530 11/20/2019
* Remove and replaced F Tube. 143,670 11/27/2019
* Removed and replaced windsheild through
Safelite. 144,088 12/10/2019
* Remove and replace flywheel, clutch, throwout
bearing and rear main block cover/rear seal bolts
and gasket Corey/ProTek 144,656 01/28/2020
* Changed both FOB batteries 144,718 02/03/2020
* Changed power steering return lines (NAPA)
and reservior (Amazon) at Corey/ProTek 144,818 02/14/2020
* Replaced the waterpump, thermostat and both
belts with GM parts at ProTek. 145,141 02/21/2020
* Remove and replace all coolant hoses at
ProTek 145,500 05/04/2020
* Remove and replace the OEM transmission
shifter with an MGW shifter and the torque
tube assembly at ProTek. 146,856 05/04/2020
* Remove the radiator and replaced with a
Dewitts 3 row aluminum radiator. ProTek 148,410 08/30/2020
* Remove and replace valve cover gaskets and
grommets, NAPA Felpro 149,520 09/22/2020
* Remove and replace Optima Battery,
Advanced Auto Parts. 149,587 10/07/2020
* Remove and replace coolant tank cap
AutoNation 149,913 10/20/2020
* Remove and replace power steering cap
and tighten hose clamp on waterpump at
Protek. (No labor charge-doughnuts) 151,658 01/29/2021
* Remove and replace interrior trim F-Strap 152,102 02/26/2021
* Remove and replace front and rear sway bar
bushings GM parts fron Rockauto.com 152,464 03/13/2021
* Remove and replace both FOB batteries 153,316 03/26/2021
* Added small amount of coolant. 03/29/2021
* Due to road debris damage front bumper cover
replaced and painted, also replaced right fog
lamp, right brake duct, right fender liner and
complete air dam. AutoNation body shop. 154,019 05/05/2021
* Remove and replace oil pan gasket and motor
mounts at ProTek. 154,995 06/16/2021
* Replace right rear wheel well liner,
right backup light and diffuser. Due to
previous accident. AutoNation body shop 155,400 07/22/2021
* Remove and replace timing chain cover
gasket, including new waterpump gaskets
and new ATI harmonic balancer,
coolant changed and alignment at ProTek. 155,902 08/24/2021
* Remove and replace front leveling bolts.
West Coast Corvettes, labor Jack Tucker. 155,918 09/08/2021
* Removed and replaced steering wheel with
new steering wheel with radio controls.
HGA Performance (EBay). 157,373 11/01/2021
* Remove and replaced the power steering
cap (AutoNation) 158,423 12/07/2021
* Remove and replace turn signal switch.
Cultrag 158,637 12/13/2021
* Remove and install radiator, radiator sent
to DeWitts 01/24/2022 for warranty repair. 159,308 03/05/2022
* Removed and replaced the rear axel nuts
with Loctite 272 and torqued to 160Lbs. 159,579 03/15/2022
* Repaired and painted both rockers and
buffed hood. Mark Sharrone. 160,060 04/02/2021
* Replaced the right and left front air deflectors
Corvette Central. 160,801 04/12/2022
* Replaced the oil drain plug, AutoNation. 163,722 04/28/2022
* Replaced heimbox rivet. AutoNation 163,045 05/24/2022
* Remove and replaced the water pump.
AC Delco/Amazon 165,813 06/13/2022
* Removed and replaced the valley cover,
new injector O Rings, new intake
manafold gaskets and new oil pressure
switch. 166,118 07/07/2022
* Replaced the number 1 FOB plastic
shell/Amazon 166,833 07/22/2022
* Replaced the right and left front air dams
EBay 166,870 07/24/2022
* Remove and replace coolant sensor/NAPA 167,046 07/28/2022
* Remove and replace the coolant sensor plug
EBay/Jack Tucker 167,360 08/08/2022
* Remove and replace starter motor. NAPA
under lifetime warranty at Bill Guevremont's
house. 168,011 08/20/2022
* Got a warning the ABS/Traction Control was
giving a code. Purchased a code reader and
determined the problem with in the right front
circut. After examination found that the plug
from the ABS wiring harness to the right front
ABS sensor was taped together probably by
ProTek. Plugs are brittle due to heat and age.
Determined I could use a wire tie to hold the
plug together and no further codes showed up. 168,244 08/23/2022
* Driver's seat adjustment **** replaced due to
original falling off and out of the car.
AutoNation 169,595 09/23/2022
* Added a small amount of coolant. 173,036 01/09/2023
* Removed and replaced the radiator under
warranty from DeWitts. Replaced all four
hose clamps from NAPA. Broke the EGR
valve and replaced with a new one from
AutoNation 173,508 01/23/2023
* Removed and replaced the right wind
deflector due to road damage. (EBay) 173,859 02/01/2023
* Remove and replace the brake master
cylinder. Part under NAPA warranty. 174,984 03/06/2023
* Removed and replaced the power brake
booster due to damage from the faulty
master cylinder, O'Reilly's Auto Parts. 174,984 03/11/2023
* Remove and replace the right front air
dam. 174,984 03/12/2023
cylinder due to previous replacement
being defective. Amazon AC Delco 175,204 03/26/2023
* Remove and replace both front outer
tie rod ends. Amazon/Tire Choice 175,358 03/30/2023
Motor under NAPA warranty. Labor
through Affordable Auto Repair. 180,343 09/13/2023
* Repaired the number one FOB and
replaced the battery. 180,855 10/09/2023
After reading the C8 forum threads. No doubt the C8 is an awesome sports car but DIY maintenance is no longer part of the equation with C8 ownership. Definitely not without a car lift. DCT transmissions are a notable high maintenance issue with mandatory dealer fluid and filter flushes at 7k miles and rates are as high as $2k for a trans fluid change. A new DCT is running around $25k-$30k for R&R, when out of warranty. Many people say the DCT will require a replacement well before 100k miles.
I am NOT bashing the C8, just saying it's not as DIY friendly as the C6 and I don't think as reliable, especially long term (100k).
Diff Oil Change
Engine Air Filter
Brake Fluid Flush
Coolant Change
Cabin Air Filter
Wiper Blades
40,040 12/30/2011
54,383 01/16/2014
86,400 09/04/2015
124,114 12/02/2017
144,192 12/12/2019
Clutch Fluid Change
Tires
Brakes
11. Maroone
Mid America Parts
warped OEM rotors.
work included:
> Replace brake fluid
> Replace coolant
the tonneau cover.)
You guys are correct about the maintenance issues. I have been watching UTube and about the only thing I can probably do myself is an engine oil change. Members of my club have lifts but I would be hesitant to do the transmission flush and filter change without an up to date programmer.
As for the comments concerning the C6 engine longevity. 181,000 was nothing there are members her on the Forum with far more mileage.
There is a guy in Jacksonville, FL that donated his C5 to the museum with over 500,000 miles on the odo. The only major maintenance was a valve job at about 450,000 miles. The car was an auto and never let him down. His daily commute was in Brunswick, Ga.
Modern metallurgy has really extended engine life.
