Back up camera and GPS
Old Dec 8, 2023 | 10:26 AM
Rev117's Avatar
Rev117
4th Gear
Default Back up camera and GPS
Greeting to all, I just got a 2012 Grand Sport Z16 convertible.
I want to put in a back up camera and navigation, any suggestion on replacement units that fit what I'm looking for and works well with this type vehicle?
Thanks in advance.
Rev
Old Dec 8, 2023 | 03:03 PM
Moved this to C6 General.
Old Dec 8, 2023 | 04:09 PM
BobGs10's Avatar
BobGs10
Cruising
Thanks in advance.
Rev
I put a Kenwood unit in my 2010 GS, came with front and rear cameras and Garmin GPS, improved the sound as well.
Old Dec 8, 2023 | 04:13 PM
madsonp's Avatar
madsonp
Yep, go with a quality aftermarket system, the stock systems are way out dated. A quality aftermarket has the latest tech that the stock systems don’t have, and they sound quite a bit better.
Old Dec 8, 2023 | 04:25 PM
madsonp's Avatar
madsonp
Also look at the ones that Crutchfield carries. https://www.crutchfield.com/S-ipZZdFIMxTi/ They can help you with everything you’ll need for installation i.e. interface, dash kit etc. Keep in mind their fitment guide isn’t always correct, pretty much any Double DIN systems will fit in the C6 with a few exceptions. I suggest you decide on a unit, then go to the Audio/Electronics section of this forum, and ask if anyones had any issues on installing that particular model, plus we can offer you some tips and tricks to help you with your install. https://www.corvetteforum.com/forums...lectronics-20/
Old Dec 8, 2023 | 09:47 PM
kkupec02's Avatar
kkupec02
welcome
Old Dec 9, 2023 | 07:37 AM
seijack's Avatar
seijack
Welcome to the forums! Crutchfield is your friend. I would not worry about a navigation unit. Go with a multimedia unit that has android auto or apple car play. I chose wired but If I had to do it over again I would go with wireless, Crutchfield has excellent customer support and great instructions. I can also recommend getting the plug and play wiring harness. Good luck.... Lets see some pics of that car!!
Old Dec 9, 2023 | 08:13 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
I can tell you use your phone with Waze is better than any GPS you will install.
Old Dec 9, 2023 | 09:36 AM
PMPerformance's Avatar
PMPerformance
ditto, do not waste money for onboard GPS. Your phone updates regularly where the onboard maps will not
plus there is a pretty drastic price difference
Old Dec 10, 2023 | 12:30 PM
FLC6GS's Avatar
FLC6GS
Crutchfield is your friend and installation customer support is great. My rep (Red) set me up with everything I needed installation wise. I just did my installation about 2 months ago; head unit, amp, 6 speakers, both front & rear cameras. Bose amp blew, not necessary to mess with center dash speaker, just disconnect it. I agree to use your phone for the Maps (Google/Waze) and not a GPS headunit that requires manual map updates.
I went with a Kenwood headunit that specifically had a physical push button to activate the cameras (DDX9707S). It's an Android wireless unit. Cam button is a great feature at your finger tips to manually activate either one at any time. Reverse cam comes on automatically in R and the HU has a feature that allows auto activation of the front camera for 5-15 seconds when coming out of reverse. The cam button on the HU is nice when pulling into a spot. Tap the cam button and then Front on the display for the cam view. It is a deep unit and fit, but a little snug with all the wiring from the PAC unit. Hindsight, maybe would've gotten the one that looks like it's 1/2 the thickness of the headunit, but it was at a great price.
Only 1 CON - Wireless Android does drop frequently, at least once every 30 minutes for 30 seconds to a minute. That can be crucial if you're using a map and it goes to its connectivity screen and the map disappears. I still utilize mostly the wired connection for charging and connection stability.
Phone Holder - ProClip Angled Dash Mount #854233 with holder to your phone make & version. As you will see it mounts, directly next to the HU so there's no issue with phone being too far/obstructed with wireless signal loss.
Crutchfield - pay the $25 and have them wire the PAC RP5-GM11 Wiring Interface to save yourself a lot of time. I used it and it retained all of my steering wheel controls (Bluetooth & Radio) default controls.
Cameras - I would recommend a license plate cam for at least the rear and both if a front plate is required for your state. License plate cam (Amazon
HD eRapta Backup Camera HD eRapta Backup Camera
) will be centered and not skewed off angle, just a bit more easier and possibly accurate than one flush mounted off center by the license plate lights. I don't have a front plate, so went with the round on that just presses into one of the honeycomb openings in the grill (Amazon
Flush or Bracket Mount NATIKA Reverse Rear View B Flush or Bracket Mount NATIKA Reverse Rear View B
). Has stayed put and aligned from day one as a daily driver.
Amp - used Kicker 47KEY200.4 which was the perfect size to fit in the space where the Bose Amp was. Didn't feel like redoing everything to fit amp behind a seat.
Speakers - JL Audio C2650 for front doors (6-3/4" Sub/ 1" Tweeter/Crossover) and Polk Audio DB 522 4-1/2" for rear. Rear speakers, don't tap off factory wiring if you want to be able to us Left/Right independently. Metra C6 dash kit for headunit and speakers both worked great too.
Console - while you have it all apart consider replacing the cigarette light and then the Aux Port that is in the Center Console. In the image the one with the LED I used in the Lighter area and tapped off the lighter wiring. The connector with the 2 different sized USB ports I used in under the console lid and it connects to the 2 Kenwood USB cables for power and data. Required no modification to either OEM opening.
Whatever you do make it your own system and test everything before reassembling console. Any questions at all, let me know. Cheers
Old Dec 10, 2023 | 01:02 PM
Ap2Iven's Avatar
Ap2Iven
This is the system I went with from Crutchfield , my brother has the previous gen radio on his Z and I liked how easy everything is. The price for this unit was very cheap for Apple car play and android auto and all you need after is a $20 Amazon back up camera
Old Dec 17, 2023 | 09:24 AM
Rev117's Avatar
Rev117
4th Gear
Nice, a Vet with a Vette. Thanks for your service.
Old Dec 17, 2023 | 10:30 AM
Dzv69's Avatar
Dzv69
I went to a pro audio installer.
Kenwood DMX9708S, front and rear cams
Old Dec 17, 2023 | 09:31 PM
FatChance's Avatar
FatChance
I have the same Kenwood in my C6 and really love it!
Old Dec 19, 2023 | 01:05 AM
Chukman's Avatar
Chukman
I'm currently looking at this 9708S for my '08. Assuming the rear camera activates when shifting into reverse, how does it allow you to select/view the front camera? Is there a display button on the display that's easily accessible? How do you like the 9708S overall, pro's, cons? Can you install a custom screen picture such as a C6 flags logo?
Crutchfield also has an Alpine iLX-407 that seems comparable but I have the same questions for that unit too.
Old Dec 19, 2023 | 11:41 AM
BobGs10's Avatar
BobGs10
Cruising
Old Dec 19, 2023 | 11:42 AM
BobGs10's Avatar
BobGs10
Cruising
I added this custom background on my Kenwood, I'm sure the other brands would also have this capability.
To Back up camera and GPS
Old Dec 19, 2023 | 11:52 AM
hawkgfr's Avatar
hawkgfr
Check this out before you buy....Its new and made specifically to fit C6 Corvette....plug and play....More than just a radio and camera...
https://www.knightdrivetv.com/collec...loses-june-2nd
Old Dec 19, 2023 | 07:34 PM
Dzv69's Avatar
Dzv69
The front camera has a button on the perimeter of the unit labeled CAM. I'll check on the reverse Cam functionality, haven't used it in awhile.
I would definitely recommend the 9708S, it has much much more power than the factory unit and of course has Apple Car Play, and all the fancy software. I haven't looked into if it can load external files/images, like the Corvette flags, i'll check into that too. I would not hesitate to purchase this unit again if i was doing it over.
Old Dec 20, 2023 | 02:34 PM
FatChance's Avatar
FatChance
I am quoting my own post to correct it (senior moment). I have the Kenwood Excelon DMX908S, not the DMX9708S. The DMX908S is exactly like the DMX9708S, except the DMX908S also has HD radio and a 2 year warranty (vs 1 year) but costs about $50 more.
