Having a slow coolant leak in my 2007. Looked under the hood and saw no obvious leaks but most of the hoses looked like ****. They have never been changed. The problem is that besides the upper and lowered rad hoses there are a million hoses that I do not know the name of. Is there a list that gives the name and /or part number for every coolant hose under hood. THANKS
I had a slow leak back in the day, and could not find it. I did a 12 hr pressure test on the system and finally found the leak coming from the water pump seal. I guess when the car was hot, it would just drip to a hot surface and evaporate. I could smell the coolant but no sign. Long story, I replace the pump, changed all the hoses to Silicone, and no worries since.
The inside of the pump pulley was caked with coolant residue.
Same here on my 07 C6. Coolant loss, smelled coolant, nothing on ground. Loaner pressure tester from Autoshack....no drip when cold, found drip when warm. Water pump seal.
Seems like the most common place for the hose assembly to leak is at the somewhat infamous plastic Tee fitting. If so, brass barbed fittings are commonly available from your local hardware store.
When you change them, obviously change them all. When I installed the A & A S/C, I decided while I had everything apart to install a new water pump, and power steering pump, and all new hoses. Good peace of mind and easy to do with everything out of the way.
Thats what I was thinking also
I replaced mine and it wasn't even leaking cause I read they could be a problem and it's a cheap fix
