Gaining tire pressure
My wife's Mazda and her Jaguar came with nitrogen from the factory.
Air mix:
N:78%
O:21%
other:1%
All noble gasses following Boyle's Law....
Can you explain why nitrogen doesn't respond to heat the same way as natural air mixture.
Ref: https://youtu.be/bCnWvMleVD0?si=lepPqX6cze24n9zs
Air mix:
N:78%
O:21%
other:1%
On average, a semi-truck typically covers around 100,000 to 125,000 miles per year. However, this can vary based on factors like the type of freight, routes, and individual trucking company practices.
The lifespan of semi-truck tires can vary depending on factors such as the type of tire, road conditions, maintenance, and driving habits. On average, truck tires might last between 50,000 and 150,000 miles. Regular maintenance, proper inflation, and alignment can contribute to extending their lifespan.
can you explain how semi tire last longer? And, I noticed pilot truck stop has compressed air at the fuel pumps for semis
Air mix:
N:78%
O:21%
other:1%
Then the deflecting and flexing back heats up tire-matetial, wich heats up tire inside gascompound.
Dont worry about the pressure rising, worry about the temperature of inside tire gascompound it represents.
When driving high speed with yust enaugh pressure for load and speed, in ambiënt temperature of 104 degr F/40 degr C, the tire inside rises to 167 degr F/ 75 degr C. so extreme circumstances. If higher temp, it must be by external factors or to low pressure.
I am now busy making a list of pressure rising for temperature in tire.
But now I will use your pressure of 30 psi, calculated with my made temperature/ tyrepressure calculator for dry and wet.
30 psi filled at 68 degr F/20 degr C going to 35 psi, means if perfectly dry gascompound in tire, like Nitrogen claims, a temperature in tire of 127 degr F. With enaugh water in tire 115 degr F, like normal air with all the humidity.
Wich is pretty normal after longer drive with speeds of about 60 to 70 mph.
And you see that with water in tire, pressure rises more, but temperature in tire stays lower, wich cools down better the tire material.
Not a big difference, but certainly no pro for Nitrogen filling.
If you want to play with my calculator, mail me at my hotmail. com adres with username jadatis, and I will send it in return.
Like this to prefent spamm, combine yourselfes.
And the opposite is true. Many people get a low air pressure light on their cars in the winter when a strong cold front comes through.
It would be cool to see cars come out that have active air pressure systems integrated into the car to maintain an ideal pressure at all times. Would just be an air pump with air lines going to each wheel and a through hub. Would add complexity and weight to a vehicle. But cost would likely work out better with maximized tire wear over the life of the vehicle. I would rather have that than the garbage "features" they keep adding to modern cars.
