2009 NPP Issue Help Needed
Old Feb 6, 2024 | 07:25 PM
meltblown's Avatar
meltblown
Default 2009 NPP Exhaust Issue. Help Needed
Hi back again after a 14 year hiatus from vettes. Learned a lot here before and about to beat on a dead horse. I've tried to find information about this but seems nothing really works so please bear with me.
The valves on my exhaust are not closing on start up for quiet mode. I've checked the fuse, and it's in place. I want to install the control but seems to be moot if they aren't actuating at all. I really would like this thing to tone down while cruising because it's irritating with my tinnitus. Any ideas as to how this thing is routed and controlled would be greatly appreciated.
Glad to finally have another and the LS3 is perfect. TIA
Old Feb 6, 2024 | 08:52 PM
BadAV's Avatar
BadAV
There's a solenoid that fails that's located somewhere inside the bulkhead by the passenger side tail lights, or possibly underneath the car behind the lower valance.
I can't tell you exactly where it's at because my car didn't have NPP from the factory. I retrofitted it and added NPP In a Box. Hopefully someone who knows will be along shortly.
Old Feb 6, 2024 | 09:26 PM
meltblown's Avatar
meltblown
Makes sense. Trying to figure out where the actuators get the vacuum as well. Never saw a vac line stretched to the back of a vehicle
Old Feb 6, 2024 | 09:39 PM
Quick Silver Z's Avatar
Quick Silver Z
St. Jude 15 Year Donor
No-IL Events Coordinator
2025 C6 of the Year Winner - Unmodified
2019 C6 of Year Winner (appearance mods)
2018 C6 of Year Finalist
St. Jude Donor '12 thru '26
Look here...
https://www.corvetteforum.com/forums...placement.html
Old Feb 7, 2024 | 07:11 AM
meltblown's Avatar
meltblown
Awesome sir much obliged just what I was looking for
Old Feb 7, 2024 | 08:36 AM
kestell123's Avatar
kestell123
The solenoid is the most likely cause of the problem. But in my case it was a failed vaccum acctuator on the muffler it self. It was leaking vaccum so that neither valve would close. I plugged the line to one side and the other side closed. I was able to find a used replacement and have been good since.
Old Feb 7, 2024 | 09:08 AM
FatsWaller's Avatar
FatsWaller
One simple thing you could try: take the hoses off the solenoid and join them together with a short coupler. If there are no vacuum leaks causing the problem then the butterflies should close soon after the car starts and stay closed. There may be a check valve at the head of the vacuum line, can’t remember, but the butterflies should stay closed except maybe when you put you foot into it and manifold vacuum drops. If there is a check valve, the butterflies will probably just stay closed. If this proves out, then the problem is most likely with the solenoid or much less likely with the exhaust control module.
Old Feb 7, 2024 | 04:16 PM
Suehog6060's Avatar
Suehog6060
Pulling the fuse is the simplest and easiest way to solve this problem and then will have a true full time 4 tip exhaust with an extra 6 hp and better sound
Old Feb 7, 2024 | 04:54 PM
FatsWaller's Avatar
FatsWaller
Sorry, but that’s exactly opposite to what the OP wants. Pulling the fuse pretty much guarantees that the butterflies stay open all the time if the solenoid is working correctly. The OP wants the OEM method of operation where the butterflies close when the engine starts and stay closed except under the programmed rpm and throttle parameters. And if the solenoid is fused either open or shut, pulling the fuse won’t affect anything in how it is currently operating. Same is true if there is a vacuum leak or the exhaust control module has failed.
Old Feb 8, 2024 | 10:24 AM
meltblown's Avatar
meltblown
You guys are great. It was a PITA to get the solenoid out but done. Jumpered the vac lines together and the valves close. Getting 14V at the connector. New solenoid arriving tomorrow. Now will install the kit to control it. Thank you
Old Feb 12, 2024 | 08:36 AM
meltblown's Avatar
meltblown
New solenoid arrived Saturday and installed. Mild2wild also finished up. Perfect and exceeded my expectations when I tried it out yesterday. Spent the rest of the day with a clay bar and waxing.
Old Feb 12, 2024 | 09:17 AM
BadAV's Avatar
BadAV
Should have done clay bar, paint correction, and ceramic coating. I'm going to do mine after I get the 4LT leather dash reglued.
Old Feb 12, 2024 | 11:34 AM
meltblown's Avatar
meltblown
Down the road I want to get it done by a professional like you mention. For now it's more of an interim step to go over the entire body
To 2009 NPP Issue Help Needed
