Hi guys.
Do any of you have experience installing aftermarket wheels? I want to buy R19 5/120 8j et35 225/35 + 9.5j et42 255/35. I'm not sure about the offset, my base c6 has a rear disc offset of 79mm. The calculator says the front wheels will fit, the problem is the rear wheels.
So, by all means, share your experience about wheels and equipment!
Check out this site and you can see what happens with the setup based on stock versus custom. If you get outside the fender wells they will get ripped apart if you bottom out the suspension.
