Tpms sensor issues
Old Mar 17, 2024 | 08:51 PM
Tmaccc's Avatar
Tmaccc
Default Tpms sensor issues
Hey everyone so my 08 base auto back right tire sensor is reading “xx”. All other sensors are reading fine. The catch is it starts reading xx at the same spot of a highway I get onto every single time (same sensor back right). Last time it happened it turned off after awhile but this time it’s not turning off. Cant tell if it’s a communication issue or I need to replace the sensor. Thanks for the help!
edit: just like last time the sensor started working again. Weird that one specific spot messes up communication for awhile.
Old Mar 17, 2024 | 09:06 PM
sramzzz's Avatar
sramzzz
Chances are you need new ones. How old are the ones you have now?
Old Mar 17, 2024 | 09:24 PM
JABCAT's Avatar
JABCAT
I chased tpms issues similar to this for quite some time, even with new sensors. Finally purchased another new set of oem sensors and no issues.
Old Mar 17, 2024 | 09:33 PM
Chukman's Avatar
Chukman
This happened to my '08 last year on the two fronts. The XX was due to low batteries. If your sensors aren't that old, maybe the one has failed? If they've been installed for years then likely time to replace all four.
Old Mar 17, 2024 | 10:20 PM
Tmaccc's Avatar
Tmaccc
They’re probably very old as the tires are old but I jus got the car not too long ago so I’m not 100% sure. It’s just odd it only happens at this one specific spot every time. How much does replacing all 4 sensors cost labor included? And when I get new tires can I use the same sensors?
Old Mar 17, 2024 | 10:28 PM
sramzzz's Avatar
sramzzz
You can get the Schrader sensors at rockauto. Yes you can use them again when you get new tires. You said the tires are old why not do both at the same time.
Old Mar 18, 2024 | 12:31 AM
Tmaccc's Avatar
Tmaccc
they’re old but still have good tread so I’m waiting to see cracking or something from age. I just made an edit but the sensor is working again. That one specific spot seems to mess up communication for awhile and likes to scare me.
Old Mar 18, 2024 | 08:10 AM
Dreamer2's Avatar
Dreamer2
Do tires need rebalancing after installation?
Old Mar 18, 2024 | 08:27 AM
indyblue67's Avatar
indyblue67
yes.
Old Mar 18, 2024 | 08:45 AM
FatsWaller's Avatar
FatsWaller
Maybe. If the tires are new, yes.
If you’re reinstalling the old tires, and the new sensors are the same weight as the old ones, then a competent tire tech can mark the position of the tire on the rim, and reinstall it in the same place. I’ve had this done twice, and balance was not affected at all.
Old Mar 18, 2024 | 08:58 AM
tommyc6z06's Avatar
tommyc6z06
2023 Corvette of the Year Finalist - Unmodified
2022 C6 of the Year Winner - Unmodified
Exactly. They can deflate and just break the bead on the valve/sensor side, push down and swap the sensor without a dismount. No need to rebalance if it was fine before
sramzzz's Avatar
sramzzz
If the tires you are running are 7 or 8 years old they need replaced regardless of tread. You probably won't see them crack but simply lose traction as the compound has broken down and is now hard.
Old Mar 19, 2024 | 03:54 PM
LLL 746's Avatar
LLL 746
2nd Gear
Although there is a small possibility that the area where you lose the signal from that sensor could have some form of higher-energy radio signal that would override your sensor (unlikely because all four sensors are on the same frequency), it is more likely a TIME issue: it always takes you about the same time to get to that spot. That's a good chance that the battery in the TPMS is failing.
Old Mar 19, 2024 | 04:09 PM
FatsWaller's Avatar
FatsWaller
There’s an easy way to check if it’s the sensor or a coms error if you have a TPMS programming tool. Program the sensors in the reverse order by starting at the LR wheel and proceeding counter clockwise. This will swap the logical position of the sensors front to back. Then drive to the spot where you get the xx error. If it’s the sensor it should be reported as RF if it was being reported as RR before. Don’t forget to reprogram them back in the correct order after.
To Tpms sensor issues
