C6 starting problem
Old Mar 27, 2024 | 01:46 PM
Dcdurham's Avatar
Dcdurham
Cruising
Default C6 starting problem
My battery is 2 years old, tested ok. Alternator OK. After leaving off for 3-4 hours, car will not start. No clicking, like it's trying to start. I can't even open the door. New battery in fob. Please help!
Old Mar 27, 2024 | 01:49 PM
Vette_DD's Avatar
Vette_DD
Check the voltage on the "new" fob battery.
Where is the fob located when you're trying to get in the car?
Old Mar 27, 2024 | 07:30 PM
gdmoore01's Avatar
gdmoore01
Fob batteries rarely fail suddenly, the battery starts to weaken and the first thing that you notice is the fob is not picked up by the C6 antenna system to allow you to gain entry, although you can usually hit the unlock button successfully to enter the car. After checking the battery voltage (should be 3.3v new) you need to confirm that you inserted the battery properly in the fob, also, you should have cleaned the battery contacts and made sure that the contact tension is sufficient to make good contact with the battery.
If the fob is in your pocket when you approach the car, you should be sure to not have any other electronic device in the same pocket (phone, etc.) as these can interfere with the signal. Also, is the car is parked in a location you don't normally use that is near anything that would pose radio wave interference?
Any messages on the DIC in your instrument panel? Before you try to start the car, you should hear some subtle clicking noises coming from the center dash just above the radio where the RCDLR is located?
Did you check the battery voltage after the 3-4 hours and failed start to be sure it registered 12.4+ volts.
Try to give us as much detailed information as you can concerning the problem as there are several items that can be responsible for a no-start condition.
GD
Old Mar 27, 2024 | 08:02 PM
jjfabs's Avatar
jjfabs
I had a no start problem and after a new starter it worked a few times then no start again. I did a little search on this forum
and some said to remove and clean the grounds under the battery tray. Easy, free and painless, it has started every time now for
6 months.
Old Mar 29, 2024 | 09:46 PM
07BlackBlack's Avatar
07BlackBlack
I would start with just a multimeter on the battery, see what is is running, shut off, then hours or next day later and start from there.
Old Mar 30, 2024 | 06:49 PM
madsonp's Avatar
madsonp
Like others have mentioned, check the voltage on your fob battery, a fresh new one should read 3.3 VDC. Just because you think you may have bought a new one doesn’t mean it hasn’t sat on the shelf a while and could have gone bad from sitting for so long, also check that you inserted the battery in the fob correctly.
To C6 starting problem
