Car twist...
Old Apr 12, 2024 | 10:28 AM
df5152's Avatar
df5152
Default Car twist...
Good day all its been a while since I have been on the forums. I have a bit of an issue looking for some insight. I recently had my clutch and hydraulic system replaced. Ever since then while driving the car if you are hard on the accelerator you can feel what I am describing as a twist. One side of the car seems to push harder than the other. I have looked at everything under the car that I can think of all seems good. No bad tie rods the rear cradle is tight everything seems as it should. What should I be looking for next? Thanks Dan.
Old Apr 12, 2024 | 11:15 AM
Mike98SilVert's Avatar
Mike98SilVert
Active Streak: 90 Days
Motor mounts
Old Apr 12, 2024 | 11:16 AM
yeller z06's Avatar
yeller z06
Perhaps because you could never give it hard acceleration before with your worn clutch? There's going to be some twist from the torque of the engine, but it shouldn't "push" the car from one side. It's not losing traction or flashing the traction light, is it? Are the tires good?
Old Apr 12, 2024 | 01:56 PM
df5152's Avatar
df5152
Originally Posted by Mike98SilVert
Motor mounts
feels like its coming from the rear but Ill check them Thanks
Old Apr 12, 2024 | 01:57 PM
df5152's Avatar
df5152
Tires are good plenty of tread. No traction control lights and no wheel spin....
Old Apr 12, 2024 | 11:20 PM
VetteVinnie's Avatar
VetteVinnie
Motor mounts
My Z06 was getting horrible wheel hop at the drag strip. When we pulled the engine for a different problem, this is what we found. I replaced them with Hinson urethane along with the transmission mount. Between those and DRM Bilstein shocks, no more wheel hop.
Old Apr 14, 2024 | 09:52 AM
df5152's Avatar
df5152
Thanks for the info.
To Car twist...
