TPMS Program
Old Apr 18, 2024 | 11:47 AM
2008_aught-six's Avatar
2008_aught-six
Cruising
Default TPMS Program
So I bought some new wheels/tires/TPMS and I want to take them somewhere to get mounted. Normally I would just take the whole car to Discount and have them knock it all out but with these wheels being a bit nicer I'm looking for a local performance shop to just mount the new tires and then I'll bring them back to my house to be mounted after I've knocked out a few other suspension items. What's the process on the TPMS program/relearn? Do they need the car (or the old wheels/tires) before installing the TPMS and mounting the tire to reprogram? Or can they get it all mounted for me and I drive the car back and they program it?
Sorry I've never had to deal with replacing TPMS so I'm not very informed on the subject.
Old Apr 18, 2024 | 12:20 PM
VetteVinnie's Avatar
VetteVinnie
It's actually pretty easy if you have the trigger from Amazon (https://a.co/d/0acHGxO). It says Ford, but it works on a number of brands including Chevrolet. It's what I use. Alternatively you can let some air out or the tires:
1. Turn ignition to AUX position with the parking brake engaged
2. Press and hold unlock and lock buttons on the keyless entry transmitter until horn sounds.
3. Starting with LF tire increase/decrease the pressure (or press the TPMS trigger near the valve stem) until horn sounds.
4. After horn sounds proceed as in step 3 for the next 3 sensors in the following order: RF, RR, LR, After completing LR tire horn will sound twice.
5. Turn ignition to OFF position to exit vehicle learn mode. Adjust all tires to pressure listed on tire placard.
Old Apr 18, 2024 | 01:00 PM
2008_aught-six
Cruising
So that sounds like what I need to do to tell the car which sensors go to which tire. But is there another programming step for new sensors just so the car recognizes them? Or does the car see/talk to them right out of the box?
Old Apr 18, 2024 | 01:14 PM
6 Shooter's Avatar
6 Shooter
Here’s a YouTube video…
Old Apr 18, 2024 | 02:18 PM
VetteVinnie
As long as they are the right sensors for your car, there are no additional steps needed.
Old Apr 18, 2024 | 05:09 PM
2008_aught-six
Cruising
Awesome, thanks!
Old Apr 18, 2024 | 05:41 PM
jamieo's Avatar
jamieo
I wouldn't trust anyone but Discount Tire for my installs.I am sure there are local shops that will do an awesome job but DT will stand behind their work and will promptly address any issues or concerns.
Old Apr 19, 2024 | 06:11 AM
jamieo's Avatar
jamieo
Originally Posted by Discount Tire
Thank you for the recognition and your kind words, we greatly appreciate it.
Your company has earned it from me.I had a small issue at the store I use and they made it more than right.My only complaint is that they didn't have a way to get my cars on the alignment rack.
Old Apr 19, 2024 | 09:52 AM
hcbph's Avatar
hcbph
Obviously not the same store, but I've used Discount Tire for years and well pleased with the results, In fact one year I needed 4 sets of tires for 4 vehicles and they all came from DT. The day I need more tires, DT will be my first stop.
Old Apr 22, 2024 | 05:02 PM
VetteVinnie
Here's a fun fact. 2011 and newer (unless it's an early 2011 from the second half of 2010) REQUIRES the TPMS trigger. The air method doesn't work. Fortunately, the TPMS sensors that Discount Tire installed onto my car-less ZR1 wheels worked beautifully with my $15 TPMS trigger from Amazon just like it did with my ZR1 back in 2020.
Old Apr 22, 2024 | 05:13 PM
FatsWaller's Avatar
FatsWaller
The procedure requires the car to be in AUXILIARY mode, not RUN mode. I’m sure of this because I’ve done it before. Here is a pretty good write up of the procedure, including which years the pressure drop method will work. And if using the tool, the sensors can be programmed without mounting them on the wheel. Just place them on ground near the wheel they’ll end up in, and use the tool on them. Label them so you’ll know which wheel to put them in. This de-risks mounting sensors which don’t work with your car.
https://www.corvettesalvage.com/how-...3-c6-corvette/
Old Apr 22, 2024 | 06:14 PM
VetteVinnie
You're exactly right. I had copied and pasted the above from another forum thread, but I actually JUST went through this yesterday. For the life of me, I couldn't get it into the program mode until I finally looked it up again specifically for my 2011, and not only did I learn AUX mode with the parking brake engaged, but I also learned that the letting out or adding air doesn't work on later models and requires the TPMS trigger.
The more you know.
To TPMS Program
