Inexpensive path to front light bulb replacement?
Hi Gents,
The driver side DRL turn signal bulb in front has gone out.
The no tool solution of turn the wheels and have a monkey whose hand could fit around the corner and accomplish the push, turn pull did not work for me.
Next best appears jacking the body (some kind of low profile jack or 2x8 or 2x10 drive up on) appears to be cheapest least tool plan B.
Can I use a scissors jack and puck under the driver side front frame spot to just jack the body up enough to have the access panel clear the top of the tire, and place jack stands under the driver side rear lift spot,
and front stub frame lift spot, driver side (with pucks) and be safe?
I really want to avoid a trolley jack I will never use for anything else, 25 inch breaker bar and torque wrench for getting the wheels off and back on to do the same.
A plan B would probably to buy all the bulbs for both sides and pay Goodyear to put it on a lift, remove the wheels and have at it.
At my 100 miles per week, it would probably me my last time.
Sorry, I know many of you are hands on mechanics and purists.
I just want to drive it.
It has been 35 years since I did anything besides sound equipment and deadening on a car.
Thanks,
Atl Eng
Thanks,
Atl Eng
Tired Boy
Hi Gents,
Thanks,
Atl Eng
Thanks,
Atl Eng
plan A: learn to do basic repairs yourself. There’s a TON of tutorials on YouTube for everything and the satisfaction from making a repair yourself feels great IMO.
Plan 2: pay someone to do it. Be at someone else’s mercy for every little repair.
FAUEE (04-29-2024)
rc51racer (04-30-2024)
Hi Gents,
Thanks for the nudge.
Re: Someone at C6 specialty shop: Corvette shops are backed up 90 days in ATL and one of the supposed "best" butchered my 06 convertible prior to this coupe for $4000 electrical work. I was lucky to get out from under it.
Time to do the easy stuff myself, the fewer incompetent hands on my car the better.
I will pick up this jack, a long breaker bar and torque wrench for the wheels, jack stands, and rock and roll.
(43 Vette owners raved about it)
https://www.harborfreight.com/15-ton...ump-64545.html
AtlEngineer.
AtlEngineer.
That's not the jack you want. Get the Daytona low profile long reach. That jack is weak and only suitable for hauling to the track for racing use.
I have both. Don't waste your time with that one for your garage.
That 1.5 ton Pittsburgh jack is fine, and it's plenty for this job in particular. I have been using that jack for 8 years without any issues, doing much more significant work than changing light bulbs. As always though, buy a jack stand too, don't get under the car with just the jack supporting it.
Thanks!
if I had the space in the garage I would get the heavier one that would stay and wheel. This one will be stored in the basement for the occasional bulb replacement. Biz partner’s former 2005 went 3 years without single bulb replacement. Me? This bulb out in 2000 miles and one year of ownership. Anyway I am ready!
Curious that 43 of the 8k 1.5 T low profile aluminum Jack buyers specifically mentioned working perfectly for Vettes and folks here had some bad experiences.
Thanks! I wouldn’t get under a jacked car without jacks blocks and solid wood, even hands in the space above wheel and tire as intended. Jacks on order.
There's also a big delta in the expectations of people. Some people are fine with a light duty jack, they're gonna use it once every 6 months and if it takes 100 pumps to get it up that's better than their usual. But others have used a good jack before, and don't want to have to deal.with a weaker jack.
Personally I'd go with the Daytona version of the aluminum jack for another $30 bucks if I wasn't gonna lug it around. But only after debating spending the $300 for the low profile Daytona aluminum jack.
This, from the “How To” section of this forum should give you an idea of how to access the bulbs. https://www.corvetteforum.com/how-to...-signal-368570
Thank you!
That post is where my search for a floor jack began!
"Jacking up the car to get easier access to the access panel."
AtlEng
Thanks Fauee!
It's just a light duty jack. Mine also lost a lot of lifting power over the years. It still works, but you really have to give it the beans to get even the Vette up..larger vehicles? Forget it.
Dog Factor failure reported ranged from .8%for the Steel 3T Daytona, but 79 lb, and 1% for the 1.5T Aluminum Daytona (The Winner), on up to 1.6-1.7% Pittsburg 1.5T Aluminum and 3T Steel.
Longer ago dragging 80 lb up and down outdoor stairs from basement to garage would not have been a big deal. As 74 year old down to a scrawny 161 lb, not in the plans.
I just won't be using it much, and have no space in the garage.
But based on your great recommendation, I will return the Pittsburg 1.5T Aluminum jack and pick up the Daytona 1.5T Aluminum jack tomorrow.
Thanks again.
AtlEng
