Obd2 port issues
Old May 23, 2024 | 03:40 PM
Ba1dw1n's Avatar
Ba1dw1n
7th Gear
Default Obd2 port issues
Hello, having an odd issue with my 2006 z06. After I plug something into the obd2 port, whether it be my HP tuner, a obd2 scanner or even a simple obd2 extension cord while the vehicle is running, shortly after it will throw the "service active handling" error.
I feel like it may be a ground issues therefore would like to clean / inspect the grounds of the #4 and #5 pin. #4 being the chassis ground and #5 being the ecm ground.
Any help locating these ground points or any other suggestions to correct this issue would be greatly appreciated.
Thanks,
Old May 24, 2024 | 06:37 PM
C6ToGo's Avatar
C6ToGo
You afraid the Old Smokey is going to swing his door open too wide?
Read post #7
Old May 24, 2024 | 10:07 PM
Ba1dw1n's Avatar
Ba1dw1n
7th Gear
Read post #7
nah, I parked them both there.
To Obd2 port issues
