Speaker Replacement - HI FI Replacements
Granted that GM put thumpers in the doors, such does not need to happen, if you are installing a sub woofer in the back instead.
And then we get into if you just want loud, or if you want clean.
In the later, anything short of D amp to drive a sub woofer only, is not going to cut it.
https://www.crutchfield.com/S-saeA0h...0aAqJgEALw_wcB
Is an example
Or
https://www.crutchfield.com/p_301SV2501/Hertz-SV-250-1.html
Clean is very important
You have to decide how far you're willing to go. Are you gonna be running an active DSP? How are your fab skills to get the speakers installed right? Are you expectations in line with what you can expect out of a small sports car with low profile tires, decent road noise, and a fair bit of exhaust sound.
End of the day, the install matters more than the gear at the level of equipment you're talking about, and probably even a bit under it.
I'm somewhat kidding here, but Dyn is definitely higher end than Focal. Focal makes some nice.prpducts, but they really cheapened themselves with their entry level lines. It'd be like if Ferrari decided to create a Fiat 500 competitor priced in line with it.
One thing i learned working in the static environment of a home vs a car, it just doesn't matter in a car... road noise, wind noise, weird shaped cabins, lack of power ect ect, ive heard 500$ systems sound better than 5k systems in a car just because it has better mounting points.
Anyways, just wanted to Chime in i really like Infinity i used to run MB quart and nakamichi amps long ago but i think they have turned into super cheap garbage the last decade, if they are still in business.
As for Subs, never had better than JL
You can definitely use it to lower the resonant frequency of a panel. That sometimes helps with road noise. You can definitely use mass loaded vinyl to block some additional sound transmission. It's all a question of how deep you want to go(and how heavy), and for what gain.
If I was gonna do a thing I would use a small amount of tile based deadeners. Reality is you don't need to cover your car in foil backed butyl, the best way to do it is to use a product that applies over a smaller section with a nice thick bottle layer and a sturdy backing foil. It will give you all the benefits of most deadening, without the weight. You also don't get to totally rip out your interior for a few days while you roll stuff on every panel.
OK - so here is an update on what I am going with for the Time being. Eventually thinking some of this stuff will go more high end but i have budgets to work with an baby steps (sort of) providing input on planned upgrades later as well so feel free to provide suggestions / input as well. Most of these I have heard and like but i am open to input as well.
Alpine ILX-407 (went not super hi on this as planning on doing the Max DIN conversion later as I feel it cleans up the looks of the dash so much.
Hertz ML Power 5 - 5 channel amplifier - or Possibly my Alpine's X-Series X-A90V 5 Channel -- Depending on what i like the sound of better with this setup. Was looking to keep space down and make this an invisible install as well. Probably move on to Helix 5 or 6 channel with DSP later
4" Morel Virtus Nano Carbon Integra
8" Rockford Fozgate Mid Bass Drivers - thinking Morel ADMW9 or Morel Elate Carbon 9" down the road
5.25 Morel Hybrid Driver
Focal RCA Cables, Power/Ground Cables, 10 Ga Sky High OFC speaker wire
Going to be using a combination of Morel and Resonix Sound Deadening / Sound Absorber to clean up everything sound wise wont be going super hardcore as I dont want to add a butt ton of extra weight at the same time as well.
looking for advice on Underseat Subwoofer Options - thinking id prefer unpowered passive setups so i can use the 5 channel to power it but ultimately if it sounds good im open to whatever. SQ is top concern not Boom Boom SPL
Mostly listen to Rock, Industrial, EDM, a little bit of classical but honestly some of that puts me to sleep while driving so only a little bit while in the car.
Thanks in advance for any feedback or recommendations.
I don't think I would bother with the Rockford 8s. Those are PA speakers anyways and likely will not respond well to the door environment. The bose woofers will likely work better until you decide to spend the money on some higher end speakers.
