Headers
Old Jun 2, 2024 | 06:06 PM
ramoselian1's Avatar
ramoselian1
Cruising
Default Headers
I have a full Corsa exhaust system on my 2007 c6 base model and I was wondering if there are any headers that would bolt right on to the corsas system.
Old Jun 2, 2024 | 07:37 PM
PMPerformance's Avatar
PMPerformance
All of them.
take your pick
Old Jun 2, 2024 | 08:34 PM
jamieo's Avatar
jamieo
If you have their x-pipe only shorty headers will fit without modification.
Old Jun 2, 2024 | 11:37 PM
sirdano's Avatar
sirdano
This is what i want but dont want to pay 1200.00 for a set
Old Jun 3, 2024 | 07:45 AM
PMPerformance
don’t waste your money on an x pipe with stock headers. There will be little to no gain.
Old Jun 3, 2024 | 08:17 AM
ramoselian1
Cruising
https://speed-engineering.com/produc...0aAkjaEALw_wcB
these are the headers I’m looking into getting and hopefully they bolt right on to my corsa system.
Old Jun 3, 2024 | 08:23 AM
StayinStock's Avatar
StayinStock
2023 C6 of the Year Winner - Modified
I've run speed engineering headers on all my cars for the last 5 years... they're a great buy for the money and fitment was top notch before they changed the design. I hear the newer ones are a little worse with the o2 placement but cant say for sure.
Old Jun 3, 2024 | 09:13 AM
PMPerformance
again, they all bolt up. It’s just a slip connection.
Old Jun 3, 2024 | 09:47 AM
StayinStock
Another advantage to the speed engineering is if you run their off road X it provides all 3 combinations to make whatever exhaust work (pre 08 ls2/ls3, 09 up ls3, and z06/zr1 3 inch).
Old Jun 3, 2024 | 10:12 AM
ramoselian1
Cruising
I was trying to avoid getting there x pipe to be honest that’s why I was asking about the bolting straight on to the corsa system but I’ve heard good things about their x pipe.
Old Jun 3, 2024 | 11:06 AM
PMPerformance
You cannot bolt longtubes to a shorty midpipe without cutting a lot of pipe out.
You need to clarify what you mean by “Corsa System”.
By default they make axle backs. They also make x pipes which most do not typically buy because they are a waste of money since there is little to no gain in swapping mid pipes.
The smarter play is to run their axle backs and swap the midpipe when you go to longtubes.
Old Jun 3, 2024 | 11:41 AM
ramoselian1
Cruising
This is how it looks I don’t know much because the previous owner had it installed.
File Type: mov
Old Jun 3, 2024 | 11:57 AM
PMPerformance
ok, I would say that looks to me like you have a Corsa x pipe, just by the shine can what an oem one would look like.
yea you would change out the x pipe when you went with longtubes, hence why most people don’t go with a midpipe when on stock headers.
Old Jun 3, 2024 | 12:00 PM
ramoselian1
Cruising
so when buying my spd engineering headers I would also have to get their xpipe so it would fit?
Old Jun 3, 2024 | 01:20 PM
PMPerformance
Any long tubes you would buy, yes you would also need their mid pipe unless you want to cut and re-weld things on your current mid pipe.
Old Jun 3, 2024 | 04:42 PM
indyblue67's Avatar
indyblue67
if this is true, then why do the grand sports and higher models get a factory X pipe?
my 2012 GS has a factory X pipe.
Old Jun 3, 2024 | 05:44 PM
PMPerformance
What relevance does one have to the other? I said upgrading the x pipe. Because Chevy changed from an H to an x has no relevance to the topic. They will tell you an x has better scavenging though. Doesn’t mean there is any engine hp from it.
PS: not all grand sports had x pipes. 12/13’s did as well as some other differences in the mid pipe. Doesn’t mean it was for HP though.
Old Jun 6, 2024 | 06:51 PM
kestell123's Avatar
kestell123
Has any one added street legal cats to the Speed Engineering Mid pipe? I live in an emission testing area of Wi. so cats are a must have.
Old Jun 8, 2024 | 08:46 AM
REDSEE5's Avatar
REDSEE5
Not trying to be a negative Nancy, but be careful with Speed Engineering headers. I have heard a few people say they worked for them, but my experience with them on my z06 was terrible. No matter what I tried/how I tried to clearance them, they wouldn’t fit. Ended up returning them and ordered Texas Speed headers as I had them on my base and they fit great.
To Headers
