C6 Seats…..
Memory Seat, Mirrors and Steering Wheel On vehicles with the memory package, the controls are located on the driver’s door. 1: Saves the seating position for driver 1. 2: Saves the seating position for driver 2. B : Recalls the easy exit position. The numbers on the back of the keyless access transmitters correspond to the numbers on the memory buttons. To save seating positions in the memory: 1. Adjust the driver’s seat, both outside mirrors, and the telescopic steering column to a comfortable driving position. 2. Press and hold button 1 until two beeps let you know that the position has been stored in the memory. A second seating, mirror, and telescopic steering column position can be set by repeating the above steps and pressing button 2. To recall a memory position: • On vehicles with an automatic transmission, press and release the desired button. If the vehicle is in P (Park), a single beep sounds and the memory position is recalled after a brief delay. If the vehicle is not in P (Park), three beeps sound and the memory position is not recalled. • On vehicles with a manual transmission, when the vehicle is on, the parking brake needs to be set to recall the memory position. Press and release the desired button. A single beep sounds and the memory position is recalled after a brief delay. If the vehicle is on and the parking brake is not set, three beeps sound and the memory position is not recalled. 1-4 Information Provided by: For vehicles with the Auto Memory Recall, see “Auto Memory Recall” under DIC Vehicle Personalization on page 3-73 for more information. To stop recall movement of the memory feature, press one of the power seat controls, power mirror or memory buttons, or the telescopic steering column switch. Easy Exit Seat B (Easy Exit Seat): This button is used to program and recall the desired driver’s seat exit position. To program an exit position: 1. Recall the desired driving position by pressing button 1. 2. Adjust the seat and the telescopic steering column position to a comfortable exit position. 3. Press and hold the exit button until two beeps sound to let you know that the exit position is now programmed. A second exit position can be programmed by repeating the above steps and pressing button 2. To recall an exit position: •• On vehicles with an automatic transmission, the vehicle needs to be in P (Park). • On vehicles with a manual transmission, the parking brake must be set. B : Press to recall an exit position. One beep will sound and the exit position for the currently identified driver will be recalled. For vehicles with the Auto Exit Recall, see “Auto Exit Recall” under DIC Vehicle Personalization on page 3-73 for more information
The C5 has 3 FOB memory programming. The 3rd FOB is programmed by holding down Mem1 and Mem2 simultaneously. I have yet to try it on my 2013 C6. Maybe it works too.
I have the lumbar support and side bolsters, but no seat bottom bladder, or seat presets
I think there are other vendors offering similar.
But, if the seat collapse was sudden as described in the first post, that’s not what happens as the wires and sharp edges cut into the foam. That’s a gradual thing. This sounds more like the air bladder not inflating, as I said above.
STANDARD AND INCREMENTAL EQUIPMENT COUPE/CONVERTIBLE/GRAND SPORT
1LT
6.2-liter LS3 V8 engine, 430 horsepower 6-speed manual transmission with launch control Active Handling System, Traction Control, ABS and cruise control Auto-dimming mirrors and compass Dual power-adjustable heated sport mirrors Xenon high-intensity discharge headlamps, automatic headlamps and foglamps Air bags:1 Frontal and side-impact, driver and front passenger with Passenger Sensing System Dual-zone automatic climate control and cabin air filtration Floor mats OnStar 2 with Directions & Connections Plan for six months Keyless Access with Push-Button Start Leather seating surfaces 6-way power driver and passenger seats Tilt steering wheel with steering wheel-mounted audio controls AM/FM stereo with CD player/MP3 playback, SiriusXM Satellite Radio3 with 3-month trial, seven speakers, automatic volume, Radio Data System (RDS),4 TheftLock and auxiliary audio input jack Tire Pressure Monitoring System and run-flat tires Variable-ratio power steering
2LT
In addition to or replacing 1LT features, 2LT includes: Bluetooth® wireless technology5 for select phones with steering wheel-mounted controls Head-Up Display Bose® Premium Audio, 9-speaker system SiriusXM Radio3 with 12-month subscription Navigation radio6 with voice recognition, 6.5" diagonal LCD color display and USB port7 Luggage shade (coupe) and cargo net
3LT
In addition to or replacing 2LT features, 3LT includes: Sport seats: Lumbar/wing adjust, perforated leather inserts Power top (convertible) Power-telescoping steering column Heated seats Universal Home Remote Memory Package 4LT In addition to or replacing 3LT features, 4LT includes: Custom Leather-Wrapped Interior Package with sueded microfiber seat inserts (perforated leather inserts with 60th Anniversary Design Package), two-tone leather seating surfaces and embroidered head restraints (except Ebony); leather-wrapped instrument panel upper, door panel uppers and console cover (all with contrasting stitching); and a special gunmetal pattern console trim plate
1LT
2LT
3LT
