Fuel line
Search the GM part number and see what you get. GM 10337581. Also search for threads on how to make or buy the feed line made with rubber tubing. Also if the problem with your line is the broken retaining tabs, some have used small zip ties to hold it in position so the crossover snaps in ok.
A lesson that if you plan to keep your C6 for many years and fear parts obsolescence, don't have regrets buying parts before, or even if, you need them. I have gathered both pumps and sending units, the two tank feed lines and stainless crossover tube with line.... two hundred bucks total that I can probably unload for $1k if I don't use them. My retirement savings plan
