I have a 2008 C6 convertible that I am having issues with the external door handle to get in the car. I have tried taking the mechanism off and cleaning it but it still does not work. Sometimes it works and other times it does not. Any suggestions at all would be appreciated.
It sounds like the pad is bad. If the passenger side is working fine swap them out and you can confirm the drivers is bad and you need to purchase a replacement.
If this is not the case and it still will not open when you switch the pads, Then it would be your door latch assembly.
