Traction control issues
Old Jul 3, 2024 | 05:32 AM
Yngve's Avatar
Yngve
Default Traction control issues
Can't turn traction control off.
Guess they are all the same, 1 push, 2 pushes and hold for 5sec? With one push it turns of parts of the system, but does not respond to 2 pushes or hold for 5sec.
Any idea?
Old Jul 3, 2024 | 10:08 AM
Dano523's Avatar
Dano523
Pull codes to see what is blocking you from putting it into comp, or all nannies off mode.
With only allowing the single push, it just allowing you to turn traction control off only, but not get into comp or all nannies off mode.
Also, engine has to be running, before you start to push the button.
Old Jul 3, 2024 | 11:30 AM
gdmoore01's Avatar
gdmoore01
Do you possibly have a DIC message you have been ignoring about TPMS sensor failure "Service Tire Monitor" or any other Handling message?
GD
Old Jul 3, 2024 | 12:38 PM
JABCAT's Avatar
JABCAT
Have you done any work or removed the center console recently? Make sure the wire harness is fully clipped in. I'm having the same issue as well. I ordered a new button from AutoZone, of all places, for only $25.
Part Number: 15148444 Warranty: 1 Year Warranty Quantity: 1 Item Total: $23.99
To Traction control issues
