Service
Old Jul 7, 2024 | 01:14 PM
DESI6327's Avatar
DESI6327
Default Service
I bought my 2010 GS 9/2023 with 6,600 mi on the clock. Had all fluids changed: Oil, Coolant, Clutch. The manual isn’t clear on service miles. She now has 10K on her and has lots of oil life left. Should I bring her in for a service, or……???
TIA
Old Jul 7, 2024 | 01:47 PM
ruxvette's Avatar
ruxvette
2016 C6 of Year Finalist
Originally Posted by DESI6327
I bought my 2010 GS 9/2023 with 6,600 mi on the clock. Had all fluids changed: Oil, Coolant, Clutch. The manual isn’t clear on service miles. She now has 10K on her and has lots of oil life left. Should I bring her in for a service, or……???TIA
Just me but I change oil every 5000 miles (easy to remember...change it now at 10k, next at 15k, etc) or once per year, whichever comes first.
Old Jul 7, 2024 | 02:05 PM
DESI6327's Avatar
DESI6327
I will do that, but what about a servicing? Do I need one now?
Old Jul 7, 2024 | 02:14 PM
JABCAT's Avatar
JABCAT
Oil is when the oil life monitor indicates or 1 year, whichever occurs first. Coolant is every 5 years. If all other fluids were changed, what other service so you think it needs?
Old Jul 7, 2024 | 02:20 PM
DESI6327's Avatar
DESI6327
I don’t think it needs any service, but usually there are “Service Intervals”. That’s what I’m not sure of. This is my first Vette that wasn’t out of the 60’s.
Old Jul 7, 2024 | 03:29 PM
Joe 2008 Z51's Avatar
Joe 2008 Z51
Just drive it. You only have 3400 miles on the oil and all the fluids, and your oil should be fine for the next several months if you want to wait a full year. If you really want to do a service on it, just check the cabin air filter and your A/C system refrigerant charge. Tire life and tread (depending on the type) would be the only other item to address at this point. Enjoy the ride!
Old Jul 7, 2024 | 03:49 PM
DESI6327's Avatar
DESI6327
Thanks!!! Oh, the cabin filter was done when I bought her as well!
Much appreciated!!!
Old Jul 7, 2024 | 04:41 PM
MKenM's Avatar
MKenM
St. Jude Donor '12-'13-'14-'15-'16-'17-'18,'21
If you don't have this hope it helps.
File Type: pdf
Old Jul 7, 2024 | 05:45 PM
DESI6327's Avatar
DESI6327
Originally Posted by mkenm
if you don't have this hope it helps.
thank you!!!
Old Jul 7, 2024 | 05:56 PM
lilcuda's Avatar
lilcuda
I had my oil analyzed after 1500 miles and two track days (one was in 93 degree weather) and a year of use. Blackstone told me the oil was fine and that it could go to 3k miles. It looked great as it was draining. I could have put it in my truck.
Old Jul 8, 2024 | 08:14 AM
DESI6327's Avatar
DESI6327
Now THERES a thrifty man! 👍
Old Jul 8, 2024 | 09:04 AM
FAUEE's Avatar
FAUEE
People on these parts are way more cautious with oil for who knows why. You could run the oil for 10k miles without issues. You can run it well past a year if you want too, used oil analysis of oil that was several years old showed it to be effectively unchanged from new.
Old Jul 8, 2024 | 09:06 AM
DESI6327's Avatar
DESI6327
Thx!
Old Jul 8, 2024 | 10:05 AM
JABCAT's Avatar
JABCAT
While true, a DIY oil change on the GS (w/dry sump) is ~$70. If one is worried about spending $70/annually on the car, a Corvette was probably not the best option.
Old Jul 8, 2024 | 11:35 AM
DESI6327's Avatar
DESI6327
Ha ha ha!!!! Oil is no problem, I was concerned with Service. Full service. I think I’m good now, thx
Old Jul 8, 2024 | 12:20 PM
ruxvette's Avatar
ruxvette
Please explain 'full service'. I'm sure I'm not the only person here doing some head scratching...
Old Jul 8, 2024 | 12:35 PM
StayinStock's Avatar
StayinStock
2023 C6 of the Year Winner - Modified
I agree, this modern oil is pretty bullet proof, that being said though I'm religious every 3000 and I think its just because it was pounded into my head by every old boomer who taught me to work on cars lol. Its one of those things I wish I could shake but I cant lol
To Service
Old Jul 8, 2024 | 01:14 PM
vinny R's Avatar
vinny R
I was told you should change out the diff fluid every 25k or so depending on how hard you drive.
Old Jul 8, 2024 | 02:03 PM
ruxvette's Avatar
ruxvette
I absolutely agree. When I buy a new car I change the oil at 2000 miles (arbitrary) thinking it will dump any 'wear' metal. I change it again at 5k and every 5k after that because it is easy to remember. Every car I have 9have had) get more than 5k/year so the annual change doesn't apply.
Our big rigs went 20k miles between changes and oil analysis said we could have gone more.
Old Jul 9, 2024 | 12:28 AM
CorvetteCam91ZO7's Avatar
CorvetteCam91ZO7
Default Usually a full service
On your Birthday or Anniversary
