Head Light Bulbs
Yes something little brighter thinking of going with HID for high beam
Morimoto's are an ENORMOUS improvement over OEM headlights.
https://sharplightinnovations.com/sh...or-c6-corvette
HID bulb upgrade and LED high beam. All plug-in replacements.
Also another thing to consider is if your light are set to be on all the time they will wear out faster. I have mine switch to come one off the dusk sensor
The oem high beam projector with halogen creates a spot-ish pattern. Most LED bulbs (including ours) do not have the same focal point in the projector and as a result will create a pattern that is more spread out creating more of a flood pattern. With a good low beam projector, you shouldn't expect to see any FURTHER with high beams, only illuminate above the low beam cutoff.
There are some dedicated LED Projector high beams (like those in our Lux King system) that provide both increased range and width, but you're unlikely to get this with any LED bulb solution.
I have been running Sealight bulbs in my 2015 F-150 (low, high, fogs) for about 8 years now. The halogens in it were absolutely awful; I have been very satisfied with the output of the Sealights. I did need to adjust the beams down slightly to assure they were aimed properly.
Like the OP, I found the low beam HID OE bulbs still in place. I debated whether to leave them or replace them, since they still worked well. But since the car had 77,XXX miles, I decided to replace them. After a lot of research, I determined that these were sufficient for OEM replacements: So far, so good.
Since I'm satisfied with the halogen high beams, especially after their performance in utter darkness in the Smokies last year, I purchased these halogen replacement bulbs:
I'm glad I replaced the HID bulbs while the assemblies were out of the car. The connectors were far more difficult to remove from the bulbs than expected, and it would have been far harder to remove them in the car, than while the assemblies were out.
The total cost of the rebuild project was $332, including new lenses from forum vendor Umnitza. The bulbs were $136.21.
