2005 z06
Old Jul 17, 2024 | 03:56 PM
Pjb2643's Avatar
Pjb2643
8th Gear
Default 2005 z06
Any reason to avoid acquiring a 2005 Z06, anything to know ahead of time?
Old Jul 17, 2024 | 04:00 PM
jamieo's Avatar
jamieo
They didn't make a 2005 Z06.Started in 2006.
Old Jul 17, 2024 | 04:26 PM
Dano523's Avatar
Dano523
Yep, top of the line C6 in 2005 would be base narrow car with Z51 option, with 2SB interior.
So if car is a real Z06 with clean title showing it a 2005, then run for the hills, since its sporting a fake vin number on the car and forged tittle.
Next could be 2005 with wide body kit, but best guess lacking the dry sump LS7, much less the other items on a Z06 that make is a Z06 in the first place.
Simply, if looking at the car in person, then pop open the glove box and look a the sticker. No one in there right mind is going to remove the sticker, so if missing run, and if still there, then make sure sticker matches Vin number of dash, and the sticker does show a Z06 RPO number.
Also, as part of a PPI, make sure that they pull the vin number from ECM and BCM, to make sure it matches the vin number. Hence this is how a lot of agencies are finding stolen cars, since GM flashes are done on vin numbers, and when the vins are swapped on stolen cars, the vin number is the ecm and BCM's can not be swapped (will screw up the BCM security code to brick the car).
Old Jul 18, 2024 | 10:13 AM
VetteVinnie's Avatar
VetteVinnie
Well, to be fair, the C6 Z06 first appeared in 2005 as a 2006 model, so technically there was a C6 Z06 in 2005.
Old Jul 18, 2024 | 12:20 PM
Dano523's Avatar
Dano523
Yes, but model year will be 2006 for vin, not 2005.
To 2005 z06
