MAF sensor
Old Aug 20, 2024 | 12:49 PM
DrKrieger's Avatar
DrKrieger
Default MAF sensor
Just wondering if anyone has a recommendation for the best MAF sensor ......OEM, after market...etc? Appreciate your input....
Old Aug 20, 2024 | 02:01 PM
C6ToGo's Avatar
C6ToGo
Don't need one yet for my 07, but when I do will be either GM or Delphi, which is owned by BorgWarner. They are easy enough to swap out to consider getting a cheapie, but don't want to deal with possible trouble codes that you hear about.
RockAuto.com
Old Aug 20, 2024 | 02:41 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Always oem !!
Old Aug 21, 2024 | 12:22 AM
DrKrieger's Avatar
DrKrieger
Appreciate you advice. I have an S/C'd LS7, and it is breaking up at about 5,200-5,300 rpm. I cleaned the air filter (it was embarrassingly filthy) and I also used MAF sensor cleaner on the MAF sensor. It is a cheap unit, and I wonder if it is the reason I'm having the difficulty? I will let you know what I find out.
Old Aug 21, 2024 | 05:00 AM
StayinStock's Avatar
StayinStock
2023 C6 of the Year Winner - Modified
I'd have to say OEM too, back in my f-body days I experimented with all kinds of aftermarket ones and usually they all cause some sort of issues. Is it throwing any codes when it does it Doc?
Old Aug 21, 2024 | 06:33 AM
PMPerformance's Avatar
PMPerformance
No reason not to use oem
Old Aug 21, 2024 | 07:48 AM
C6ToGo's Avatar
C6ToGo
The $260 vs $25 is a reason some are tempted by the no-name.
Old Aug 24, 2024 | 05:05 PM
1 MEAN66's Avatar
1 MEAN66
Remember it is the OEM one that failed?!
To MAF sensor
