Dashboard squeak
I have a 2012 C6 with a squeaking noise. It is most present when going over bumps. I was hoping the noise was caused by the belt and pulley system which has now been replaced. I am preparing to supercharge so the clutch got replaced along with a torque tube rebuild. After all was said and done the squeak still persists. It seems like it may be coming from passenger side dashboard. Any advice/info would help I would like to avoid ripping the dash apart if possible.
A squeak from the dash when driving over bumps.... I have no leads.
But I will add that suspension bushing squeaks would be more common.
I also recall threads mentioning noises generated behind the stereo head unit, so before pulling the entire dash I would start by removing the center console.
Rattles and squeaks can be hard to identify.
Good hunting :
