Which Battery
Old Sep 22, 2024 | 02:55 PM
rbwinston's Avatar
rbwinston
Default Which Battery
Is either a DieHard Gold or Duralast Gold OK for my '05?? At the same price of $219 wondering if they're the same manufacturer with a different name?? Other suggestions???
Old Sep 22, 2024 | 02:58 PM
BadAV's Avatar
BadAV
Either one should be fine. As would be a Walmart Everstart Platinum, which would likely be cheaper.
Old Sep 22, 2024 | 04:16 PM
AlwaysDrivingC5's Avatar
AlwaysDrivingC5
I have a 05 and went with a Walmart battery. I've had two diehard batteries and they lasted a year. My diehards at idle 13.5, Walmart 14.5.
Old Sep 22, 2024 | 06:15 PM
ruxvette's Avatar
ruxvette
2016 C6 of Year Finalist
DieHard, Duralast, and Everstart are made by Clarios. Match up all 3 by CCA, etc and buy the cheapest
Old Sep 22, 2024 | 06:34 PM
gtovet49's Avatar
gtovet49
Default Battery Choice
I have had good results with AC Delco from the dealer. Prices were very competitive.
Old Sep 22, 2024 | 06:55 PM
449er's Avatar
449er
CF Community Team
Buy an oem AC- Delco battery with the most cca that will fit your battery tray
Old Sep 22, 2024 | 07:54 PM
leebay's Avatar
leebay
Bob, I've also had good luck with AC Delco. You might consider a AGM battery.
Old Sep 22, 2024 | 09:01 PM
rbwinston's Avatar
rbwinston
Thanks everyone for the advice. Crazy, bizarre thing happened....removed the center console to prepare for a torque tube rebuild and after unplugging the seat heater switches, 4-way flasher switch, traction control switch and cigarette lighter plug wires the car wouldn't start. Interior lights came on, green light on start button, no dash lights, no door poppers, but radio stayed on!!! Disconnected the battery ground, reconnected it, same thing. Hooked back up the console, same thing! Thought the battery had died as I hadn't started the car prior to all this. Reached out to Dano523 on the site and he suggested removing both cables at the battery and touching them together to bleed off any possible "float" voltage that could be screwing with the BCM. Reconnected the battery and varoom....started right up!!! How bizarre is that!! Took the console back out again with no problems. Guess my battery is OK after all!! However I should buy one in the near future as it's 3.5 years old. Thanks to everybody who chimed in.
Old Sep 23, 2024 | 11:54 AM
myfunz's Avatar
myfunz
I put in a Optima Red Top in my '05 works great!
Old Sep 24, 2024 | 06:13 PM
Zeke2A's Avatar
Zeke2A
Not to Bogart this thread but I inherited my fathers '05 in October last year , he had a AAA battery installed in '21 , keep it on a battery tender when not driving . Any input on the AAA replacement batteries? I'm a Aaa member so that's not an issue ... haven't had any battery issues or problems just looking at replacing possibly next year or '26 .
Old Sep 24, 2024 | 09:21 PM
ruxvette's Avatar
ruxvette
Obviously, AAA does not make batteries. Some are East Penn, some are Interstate.
AAA has about the best warranty at a good price. Make sure it's the right size (CCA, etc) and replace it with another.
Old Sep 25, 2024 | 07:42 AM
jjfabs's Avatar
jjfabs
Another nod for the OEM AC Delco
Old Sep 25, 2024 | 01:19 PM
rbwinston's Avatar
rbwinston
Very interesting.....AC Delco 42 month group 86 (which fits a C6) quoted $146 through local dealer that sponsors our Vette club. That's cheaper than anything else I found with a better warranty as well.
Old Sep 25, 2024 | 01:32 PM
NoMerlot's Avatar
NoMerlot
Costco one...$110 after core return. Been great and a lot cheaper than getting it from an autoparts store.
Old Sep 25, 2024 | 01:47 PM
YellowZ06-427's Avatar
YellowZ06-427
Odyssey Performance Series AGM Battery BCI No. 96R is what i have in mine.
Old Sep 25, 2024 | 02:16 PM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
I have been buying from Walmart batteries for decades always look for sale, with good warranty.
Old Sep 25, 2024 | 03:35 PM
C6VetteLover's Avatar
C6VetteLover
Both of my daily drivers have Walmart batteries. Zero issues, I replaced the one in my Buick because it was 8 years old but still worked.
Old Sep 27, 2024 | 08:21 AM
Gman in NC's Avatar
Gman in NC
I have always used AC Delco from my dealership. Price is with others and I average six years on them. Owned my 2005 since new.
To Which Battery
