Replacing turn signal switch
Old Sep 22, 2024 | 03:21 PM
John Row's Avatar
John Row
Default Replacing turn signal switch
Whenever I use the "right turn" signal at night the hi-beams come on. If I fiddle with the switch I can get the hi-beams off. It's getting worse. I need to replace the multi-function switch. When I search for a replacement I see several that say something about "rear fog lights". What the heck are those?
Also, does anyone know what size torque screws are used to hold the lower steering column cover?
Thanks,
JR
Old Sep 22, 2024 | 04:25 PM
jamieo's Avatar
jamieo
rear fogs are referring to the export model cars.You don't need that one.As for the screws.T-15 comes to mind.Been awhile but pretty sure that is the size.
