Battery problem
Old Oct 30, 2024 | 07:29 PM
rpeel's Avatar
rpeel
3rd Gear
Default Battery problem
A good friend of mine has a 2007 Corvette Convertible, manual 6 speed transmission. He did not buy new but has been experiencing Battery issues over the last several years. Four (4) batterys have been installed to date, the so-called Corvette Technicians at two reputible Chevrolet Dealerships say that the diagnostic tests confirm nothing wrong but yet the car battery drains itself . I've told him to make sure anything left on such as radio, airconditioning buttons are off, if there is a light in the engine compartment, disconnect. Still no results. In my opinion something electrical is causing the battery to drain . He is now on the 5th battery with the same remarks from the dealerships. He asked me to inquire on the forum to see if anyone has any idea what could be causing this problem.
I personally have a 99 Vette, convertible with 110,000 miles and I've only had to replace the battery once due to my negligence a few years back. Hopefully some one can give some realistic advice.
Old Oct 30, 2024 | 07:57 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
Most of these dealership techs are idiots and only know how to change parts so if you have no electrical diagnostic knowledge just find an auto electric shop in your area and they will figure it out…these parasitic drains are easy to diagnose and yes as your battery drains your battery service life decreases…the max drain of your battery in milliamps is normally the Reserve Capacity of your battery divided by 4…other than a fuse or possibly a relay or even a bad alternator diode can cause a draw…unfortunately we can’t diagnose this for you.
Old Oct 30, 2024 | 08:06 PM
madsonp's Avatar
madsonp
These cars always draw a small amount of power even when off, adding a Battery Tender and plugging it in when not driving the car will keep the battery fully charge, so it should address the issue.
Old Oct 31, 2024 | 07:09 PM
cadbob's Avatar
cadbob
You can buy a current draw meter for like 125.00 , than test each circuit. Least that’s what I would do.
known issue under hood light staying on
onstar drawing current
some usb chargers will draw current if left plugged into lighter
Old Nov 1, 2024 | 09:31 AM
dr_gallup's Avatar
dr_gallup
Normal C6 draw will kill a battery in about 4 weeks, If he's letting it sit for long periods then a battery tender is the solution. If it's dying in less than 3 weeks then he needs to find the excess draw. The first thing to do is pull the OnStar fuse because the service has been discontinued so nothing lost. After that it's just trying to pin it down.
Old Nov 1, 2024 | 10:20 AM
Kenny94945's Avatar
Kenny94945
If I am not mistaken, a manual transmission needs to be in reverse when parked.
Further, the interior light button, left side - on dash, is notorious for being left on accidentally.
That may be the easiest.
If I understand, 5 batteries in two years !!
Your answer is to check all the circuits/ fuse boxes to find the parasitic draw.
IMO You and your friend should DIY this, as the dealership, if doing this, has not relayed any findings.
Let us know what you all find
Old Nov 1, 2024 | 10:26 AM
C5 Diag's Avatar
C5 Diag
Only the 2005 model year has to be in reverse when shut down.
Old Nov 1, 2024 | 03:20 PM
c5arlen's Avatar
c5arlen
It's a GM thing... Learn to live with it whiles you're with Chevrolet. 🙄
Old Nov 1, 2024 | 09:56 PM
candipogo's Avatar
candipogo
Default Battery drain
Pull the on star fuse of she's still got it hooked up. It will cause a drain.
Old Nov 3, 2024 | 11:05 AM
1 MEAN66's Avatar
1 MEAN66
Almost ALL CARS have forever current drains. one example is: if a car has a Clock - the time is correct because it always has current going to it. Even if is a 60's car .
Old Nov 3, 2024 | 02:28 PM
dr_gallup's Avatar
dr_gallup
Yeah but a digital clock can run for 5 years on one AA battery cell. The C6 is a current hog.
Old Nov 5, 2024 | 02:17 PM
needhamboy's Avatar
needhamboy
Default My battery drain problem SOLVED
I converted interior lighting to cheap LED bulbs then started having dead battery problems! Problem solved with a different supplier! Check your LED bulbs!
Old Nov 24, 2024 | 05:51 PM
Musclefreak's Avatar
Musclefreak
This is a great tip. I will have to look at the owner’s manual to see where the Onstar fuse is and if it shares any other electrical functions on the car. If not, I’ll pull it on mine. I just disconnected my battery for winter storage, but during driving season keep it on a tender when not in use. Geez, these cars do eat batteries, though!
To Battery problem
