C6 a6
Old Nov 8, 2024 | 12:34 PM
Ed1801's Avatar
Ed1801
Default C6 a6
Anyone know if I can use a cheap scanner to see the air to fuel ratio? And what to look at? I feel like my c6 is running lean
Old Nov 9, 2024 | 08:55 AM
C6ToGo's Avatar
C6ToGo
A decent scan tool should show "fuel trims". Search that term on here for info. Like this
Old Nov 9, 2024 | 12:35 PM
Aardwolf's Avatar
Aardwolf
If it is lean the computer will set a code and check engine light on.
Old Nov 9, 2024 | 01:51 PM
C5 Diag's Avatar
C5 Diag
Moderator, Tech Contributor
You can use "Lambda" or fuel trims...with Lambda anything greater than 1.00 is lean and less than 1.00 is rich...anything over plus or minus 10% on long term fuel trims is a concern.
Old Nov 10, 2024 | 11:03 PM
Ed1801's Avatar
Ed1801
This is at idle after arriving to work
File Type: mov
Old Nov 10, 2024 | 11:04 PM
Ed1801's Avatar
Ed1801
and this is under load
File Type: mov
To C6 a6
