Headlight questions
First question, I’ve been having issues with the high beams not working when the fuse box is hot. The car supposedly had the recall done back in 2014 on the low beams. Is it possible the issue reoccurred and someone could have swapped the high and low beam terminal connectors at the light plug so the issue only effects the high beams now?
Second question is, on the ebay C7 style lights are the full led ones plug and play? I seen the projector ones require a square ballast and I’m not sure which I have on my 2007. I might go with the full led but was just wondering. Thanks in advance
Edit: Well i bought a set of full led morimoto style C7 lights because they seem to be plug and play. My stockers will be for sale soon.
