2013 GS -Driver Seat Module Code
Old Jan 8, 2025 | 05:18 PM
Pettrix's Avatar
Pettrix
Default 2013 GS -Driver Seat Module Code
Scan tool showed no pending codes but did show a previous history code of - Drivers Seat Module - B2860, B2861 Column Position Sensor Failure
Why would these codes show up in the history?
Old Jan 9, 2025 | 08:17 AM
C6ToGo's Avatar
C6ToGo
See conditions on when the code sets. Likely occurred at some point and may have only been a one-time glitch. I would do a Google search of the codes.
DTC B2860 Telescope Position Sensor
Circuit Description
The memory seat and telescoping steering column position settings are stored in the left hand seat control module (SCM). The SCM measures and stores the steering column position by using a position sensor, which is an internal part of the telescoping actuator. The SCM provides the position sensor with a 5-volt reference and ground. The SCM monitors the position sensor signal voltage, which ranges from 0.1-4.78 volts depending on the steering column position. The steering column position sensor becomes active only when the SCM detects a steering column switch input.
Conditions for Setting the DTC
The steering column position sensor signal, to the SCM, is less than 0.1 volt or greater than 4.78 volts for 2 seconds or more.
