Anyone know where I can find a detailed video about the speedengineering 1-7/8 inch headers on a 2011 grandsport with the dry sump system. I have heard you have to remove oil lines and I wanted to see if there are any videos out there showing that process.
I think I saw a video this past fall, linked in this forum, of someone that did the SE headers and x-pipe on his car. He couldn't get the axle back lined up right, so he took it to an exhaust shop to correct the crappy fit.
I will dig around for a few minutes and post a link to it if I come across it again.
A header install should be the same regardless of the brand, so I would check out U tube for related videos. Some header brands ( Kooks ARH) fit better & make the installation easier though
Yea I was just specifically looking for the header install on a c6 grandsport with the dry sump because I know you have to remove some oil lines to get the headers in.
Did you watch my video? I clearly outlined the specific hang up spots on a dry sump car
i just installed the 1 7/8 headers and x pipe on my
2006 zo6 dry sump…
i didn’t have to disconnect the dry sump lines…
i dropped the cradle and tilted engine to driver side and slid them in from the top on passenger side… driver side went in from bottom…
