Summit stage 2 cam
Old Mar 2, 2025 | 06:29 AM
Yngve's Avatar
Yngve
Default Summit stage 2 cam
Hi, I got a recommadation from Summit for this cam for my 2005 C6.
https://www.summitracing.com/parts/sum-8704?srsltid=AfmBOop6g_nF6gqfx8QMoahX515 0415bgGyhzmrgH4Ia29_B9ndhLFcT
To be honest, I have already installed it, but having secound thoughts when I read more about it(for carburetor engines).
What do you think?
Have ARH and Corsa exhaust as well, and still not done with installation, only cam installed.
Old Mar 2, 2025 | 07:15 AM
Spaceme1117's Avatar
Spaceme1117
https://www.summitracing.com/parts/s...Ia29_B9ndhLFcT
What do you think?
Is your car an automatic or a manual trans?
Old Mar 2, 2025 | 07:22 AM
Yngve's Avatar
Yngve
Manual Transmission😀
Old Mar 2, 2025 | 07:28 AM
Spaceme1117
You will be fine then. Will have an aggressive lope and make excellent mid and high rpm power.
Old Mar 2, 2025 | 07:29 AM
Yngve's Avatar
Yngve
Thank you!😍
Old Mar 2, 2025 | 07:48 AM
old motorhead's Avatar
old motorhead
17 degrees of overlap along with a carburetor. Ought to be a fun ride...
Old Mar 3, 2025 | 05:33 AM
StayinStock's Avatar
StayinStock
2023 C6 of the Year Winner - Modified
I dunno if anyone read this part, "Fly-cutting pistons may be required"...
It also states "Summit Racing™ Pro LS Single Plane cams are affordable and designed for racing applications where a carburetor and open exhaust are commonly found." so this cam is intended for a Carbed LS... This probably isn't what you want.
I'd go with a TSP 228r or something to that effect. Plenty of good off the shelf cams for an LS2 out there but this isn't one of them.
Old Mar 3, 2025 | 05:38 AM
Yngve's Avatar
Yngve
True, exactly my concern. Now Im worried again🤣
Old Mar 3, 2025 | 05:42 AM
StayinStock
I'd say you at least need to check piston to valve clearance. If they make contact you're going to have bigger problems than just having the wrong cam.
Old Mar 3, 2025 | 05:45 AM
Yngve's Avatar
Yngve
No contact when turning engine by hand....
Old Mar 3, 2025 | 05:55 AM
StayinStock
your call, personally I'd get something thats right for your setup before trying to run a cam thats likely going to have **** drivability and be a bitch to tune.
Old Mar 4, 2025 | 05:31 PM
old motorhead
How is your Vette being used? Street, street/strip, drag strip, road course, half mile, roll racing, impress the car show crowd, DPDI, what? Do manners, drivability, fuel eco, matter? All of that goes into making a cam choice. Not just what type of fuel/air mixer you're employing.
Old Mar 5, 2025 | 12:34 AM
Tranz Zam's Avatar
Tranz Zam
You'll have plenty of clearance with that cam. It's not all that aggressive.
Old Mar 5, 2025 | 04:34 AM
Mr.fork's Avatar
Mr.fork
That cam will feel pretty choppy and likely will have a low peak HP. I don't know this is the right cam if you're looking for balanced performance, but it should make a bunch of torque on the bottom end.
To Summit stage 2 cam
