No low beam
Old Mar 15, 2025 | 07:19 PM
LilBeast06C6's Avatar
LilBeast06C6
1st Gear
Default No low beam
I purchased two new complete headlight units and i have no low beam. There is a small wire plug but there isn't any place to plug it into.
Old Mar 15, 2025 | 07:26 PM
madsonp's Avatar
madsonp
You need to give more info, were your old head lights working fine ? What brand of head lights did you buy ? Do you have a photo of the plug you’re referring to ? Did you check fuses ? Could also be the broken wire in the fuse box issue (see post #83) https://www.corvetteforum.com/forums...dlights-5.html You can’t expect us to answer such a vague question without more info.
Old Mar 16, 2025 | 12:05 AM
DrKrieger's Avatar
DrKrieger
in my case it was the burnt wire in the fusebox.......did the work and created a jumper wire and no problems since.
Old Mar 16, 2025 | 12:46 PM
Dave S's Avatar
Dave S
Retired & lovin' it!
Default No low headlight beam
There was a recall back in 2014 for 2005-2007 C6's due to low beams being inoperative (recall bulletin #13146). This might be the cause of your problem. Although it's been quite a while, I don't think that safety recalls expire & you should be able to get repair at dealer, but could be wrong.
To No low beam
