There IS a key cylinder above the license plate. It's hard to spot. Get your eyes right under there and use a trouble light. Look closely. You will find it.
Unless someone prior removed it.
OP: GM dealers can program it I believe without the key.
There is NOT a key cylinder there... It has been removed. That is why I asked where to get one.
Thanks. I will check the local dealer. I was trying to avoid them.
Did you hit me up on my key fob programming video by chance? I feel like someone recently had this same issue and asked for my feedback.
The dealer is not the only option (IE: If you have a buddy with the hardware/software the dealer uses).
Judging by your name, I'm guessing you're in Canada - so if it's an actual Canadian car (export model) and not a US one that just ended up here, programming a new FOB has to be done with a Tech-2. Only with the domestic US cars (non-export) can you do the short or long self-programming methods extensively outlined in this forum. Actually, the long method may work for a Canadian car, but I don't think it does.
C5_Diag or FatsWaller, feel free to correct me if I'm wrong.
* US domestic cars, the speedo goes up to 200 (for MPH), with the Canadian (export) cars the speedo goes up to 300 (for KPH)
If it’s a non-export car like the one I purchased, then you can still program the fob using the bent paper clip method. All that turning the key fully does is complete a circuit back to the BCM, and you can do that by inserting two paper clips into the connector and touching them together 5 times within 5 seconds. See this post for reference https://www.corvetteforum.com/forums...post1602874270
I have to stress that the above will not work if it’s an export car that was initially delivered to a Canadian dealership.
And to add, if you can find a cylinder, then a locksmith should be able to re-pin it to match the key that you have.
You will need security access through GM as it won't program the key as it's export
